Uh oh. Like a broken cork in a wine bottle!
JBergie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JBergie Quote  Post ReplyReply Direct Link To This Post Topic: Uh oh. Like a broken cork in a wine bottle!
    Posted: 14 Feb 2019 at 6:45pm
I bought a D17 IV with a 400 series loader and noticed this- what appears to be a jammed cork in the loader. Never seen that before. Is this a job for a cork screw?
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2019 at 7:05pm
Was not uncommon to see cork in holes ,IH even used corks  in holes on frames on tractors
nonetheless ,still dead.
Just because you do not have the tools for job , it dose not make it a bad design.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2019 at 7:41pm
That looks like the reservoir for hyd. fluid. 400 series had these built in upright on one side. HTH Tracy
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2019 at 8:32pm
Is that the oil spout for adding hydraulic oil to the L/H Frame oil reservoir.
Should be able to grab it and pull it out with a large pair of Channel-Locks.
Remove the plug in bottom to flush out any pieces.
Gary
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2019 at 9:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2019 at 9:09pm
Has Tracy and Gary said that is were the hyd oil is add, on my the cap also is the breather and the bolt is installed the opposite way to not interfere with the cap go on.HTH
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2019 at 10:50pm
Got a cork screw?
Allis Express participant
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2019 at 11:08pm
I have seen corks in places like that before. Sorta supprized me. I once had a cabover ford F700 truck with a fuel tank on it. It had corks in that dad ratted shift mechanism. Not one of ferds better ideas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2019 at 3:00am
Yes remove the cork. The mud daubers and paper wasps need a place to live.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JBergie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2019 at 5:34am
(Thanks Kenny for shrinking the pic so it's viewable) It is the hydraulic spout on the loader frame. Can't get a channel lock pliers in that deep, so seriously may try a long corkscrew! (But am here in MN with an unheated ahop so may wait till it's not dumping snow or negative 30 degrees to do so)
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2019 at 7:54am
On a Series IV D-17 you should be able to use the tractor hydraulic oil reservoir and control valves, and not need the loader frame reservoir.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote JBergie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2019 at 8:02am
Gary
I was kinda thinking - it ain't broke, don't fix it!
D17 Series IV
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2019 at 9:53am
Flexible corkscrew packing puller will get down in there but it likely will come apart in pieces.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2019 at 2:59pm
Like Gary said .
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2019 at 3:23pm
Maybe you could glue something to the top of that cork and pull it out. Sort of the same idea as welding a nut onto a broken stud. Cool
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2019 at 3:29pm
What's in the bottom outlet  for suction line. Remove it. Put something in it to put air pressure in . Break up cork or drill some holes in it to pull it out .If you are not going to use in just put a old breather cap on it .
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2019 at 5:14pm
Kind of amazing how that cork lasted.
Cat put cork in the threaded wholes in trackframes of bolt wholes used to mount the dozer. Two old 1950 D6's here that have never had a blade and most of the corks are still in the wholes. I am sure it would be much easier to clean out the dry cork than mud or wasp nest or rust.
AC must of used a lot of cork for the same purpose. Thinking about it the HD5 has cork in wholes in the rear case too.
