CA power steering
techdoc48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote techdoc48 Quote  Post ReplyReply Direct Link To This Post Topic: CA power steering
    Posted: 06 Feb 2019 at 4:37pm
Has anyone put power steering on a CA?  If so how did you do it?  What type of parts did you use and where did you get them?
Doc
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 7:46pm
Maybe try the 12 volt set up like the Tractor Doctor did in Red Power magazine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 10:50pm
I've always wondered how hard it would be to adapt a 60s-70s Ford car system with the separate control valve and ram.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 10:50pm
Some one posted pics a long time ago of a CA that had the torque generator inside the tool box under the fuel tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 10:53pm
Another photo I found from a C.
Edited by Nathan (SD) - 06 Feb 2019 at 10:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 11:07pm
WHY? I went thru the steering  on my CA, fixing bad bearings and getting things lubed and set up right, and with a belly mower hanging under it, I can steer with one finger while moving.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 7:11am
Go look at the power steering on a old "A" Gleaner combine it has all the parts to convert your C to power steering.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 9:54am
The ROSS steering box on a CA is marginal at best, adding a torque generator in front of the tractor steering box is just asking it to fail. The only reason a CA should have a need for power steering, would be if you have a loader on it. Then you should consider a full hydrostatic system such as what an I-40 has. After that you will be breaking front wheel spindles.
