Gleaner K Transmission Clutch Repair |
| Author | ||
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8466 |
Topic: Gleaner K Transmission Clutch RepairPosted: 05 Feb 2019 at 6:13pm |
I figured the title would get more attention if I said this was for a K, but it's actually my 860 cotton stripper, which has the same transmission as the EIII, K, and K2, according to the AGCO Parts Book website.
I believe the throwout bearing is on its way out, as when I disengage the clutch I can hear and feel a little growling noise, and as the season has gone on, it occasionally squeals just a bit. I've replaced the clutch in my B and Ford 8N, but never on anything like this. Is it a fairly similar procedure? Anything I need to know before I dive in? I won't tear into it until we're through with our custom harvesting, but I do need to get it fixed. I'd like to order all the parts in advance and make the repair over spring break in March. Would it be advisable to replace the clutch disc, pressure plate, and the input shaft bearings, in addition to the throwout bearing? |
| Sponsored Links | ||
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3639 |
Posted: 05 Feb 2019 at 8:04pm |
Constant growling is usually an indication that the input shaft’s inner sheave hub may be wallowed out? If so, then the culprit may be that inner sheave hub’s canister spring bearing and/or no grease in inner hub.
The inner hub presses into it’s canister bearing, but the inner hub slides, with grease, along the input shaft as machine slows or speeds up. If this is the problem, it usually reguires a new inner hub, inner hub bearing, inner sheave, & input shaft. New input shaft means new input shaft/housing beatings(2), plus maybe clutch & flywheel????? So before removal of anything to gain insights, run up variable speed to highest speed setting & monitor inner sheave for trueness & take laser gun temp of components to verify is any excess heat is being generated. Just remember that the variable speed belt’s nature is to run a little warm (180-200?)degrees. Also while input shaft is running in fast mode, look to see if the outer end of input shaft runs true or not. If not, the it’s 2 housing bearings are going bad. Process to remove clutch is as follows: - place variable speed in slow setting. - on concrete, jack up & block machine lower frame in front of drive axle. - remove left drive wheel & block under final drive to help stabilize machine. - loosen outer castle nut on input shaft, but do not remove. - TRANSMISSION IN NEUTRAL, run machines variable speed from its slow setting to fast. Inputs outer tampered hub will usually pop loose. - if high variable speed belt proves unsuccessful to move outer hub, then turn off machine & rap outer hub's housing with hammer. Repeat if necessary. - with outer hub loosened, remove castle nut, washer, & outer hub/sheave, half moon key, belt, then inner hub/sheave along with its spring canister. - unbolt input shaft’s housing from transmission(8-10bolts?), frame bolts (2), and slide whole thing out & away from transmission. IMPORTANT: Place long wooden blocks on concrete where they come up to about 1” under housing/transmission. So when you pull input shaft assembly away from trans, the assembly can fall onto wooden blocks. It's much bending over, reaching, & lifting a heavy assembly. So prep wooden blocks to help support & balance it once it comes loose. Rest on the wooden blocks some, then slide blocks away one at a time to lower housing to floor. DO NOT CRAWL UNDER IT & TRY TO REACH UPWARD TO SEPARATE & LOWER IT. Edited by AC7060IL - 06 Feb 2019 at 6:44am |
CrestonM
Posted: 05 Feb 2019 at 8:13pm |
Thanks for the reply. I'm new to working on variable speeds, so I've got some learning to do. The machine is extremely low hour (no meter, but quite a bit of paint is left in the header, as well as on the trash discharge chutes) so I didn't think the hub would be worn. I have observed the sheaves at both low and high speed in the recent past, and everything looked true then, but I will look into it this weekend, doing as you say. I grease the traction drive sheave and transmission input sheave hub every day, per the operator's manual, but I understand some wear still occurs.
Also...if it is in the input sheaves, why does it only make the noise when the clutch is disengaged? That's what led me to think it could be the throwout bearing.
Edited by CrestonM - 05 Feb 2019 at 8:34pm |
AC7060IL
Posted: 05 Feb 2019 at 8:56pm |
Yes, intermittent growling could just be throw out bearing. But replacing the throw out bearing will require mostly the whole disassembly process with exception to the following if the following parts are in good standing;
- input shaft can stay in it's housing, - flywheel can stay fixed to input shaft, - clutch pak can stay bolted to flywheel. So, I gave you most culprits to inspect (temps, trueness, bearings, & wallowing) other potential while you’re doing repair. AGCO usually has all parts or can get them thru AI-parts. Flywheel can be resurfaced if 1/16”-3/32” or less wear. Wear above that makes it difficult to adjust linkage enough to accommodate loss. I have had 1/8”-5/32” wear resurfaced, but it’s nearly impossible to get clutch peddle linkage right which can cause pre-mature clutch failure. Edited by AC7060IL - 06 Feb 2019 at 6:18am |
CrestonM
Posted: 05 Feb 2019 at 9:07pm |
Thanks! I appreciate your explanations of the disassembly process and things to check. That'll definitely make it easier.
Previous experience has taught me to do preventive maintenance when taking apart something that requires a lot of time to take apart, like this variable speed. I may go ahead and change out all the other bushings/bearings/seals while I'm at it. Also, I'm not really sure what you are referring to as the flywheel. Could you elaborate on that? The only flywheel I know of is on the engine. Are you referring to the pressure plate or clutch mounting plate by chance? |
AC7060IL
Posted: 05 Feb 2019 at 9:19pm |
Inner hub should get about half a pump of grease daily. Too much grease can push by worn/flattened o-ring at inner end of inner hub, then grease ends up inside spring canister, collects dirt, & can ruin inner hub bearing, let alone gum up & restrick spring movement.
Also, don’t over grease input shaft’s 2 bearings which reside inside it’s housing. These two roller ball bearings have no inner grease covers(their balls are partially open to grease). So if that housing is half full of hot liquified grease, it’s usually happy. Too little grease is bad. Too much grease allows it to run between the bearings inner races & input shaft. When that happens the bearing’s inner race starts slipping on shaft. Have replaced several input shaft’s where both housing bearings have cut into shaft. These two bearings require press fits onto both the input shaft & outer housing. Shaft needs to be tight fit with absolutely no play. ![]() Number 1 denotes the inner hub grease zerk. This is the one I referred to that may require a half of a pump per day. As noted in the OM photo (hub may not take much grease after initial greasing.) That translates to a new tight inner hub equipped with a non-flatted oring. In time though, the o-ring wears in some & becomes somewhat flattened on it's shaft side. When that happens, then it usually requires a little grease(half a pump of grease gun) each day. Number 2 denotes the input clutch housing zerk. It says, "One stroke of grease gun per week. Over greasing may damage clutch," This is the zerk that greases the 2 partially open faced input shaft bearings. You can't see it in this photo, but if you view the parts picture of this housing (item 7), these 2 bearings (#8 & #5) are spread apart(maybe 4-5") by spacer (item 6). So there is a small cavity between the bearings. Both of these bearings have seals to their outsides, but are partially open to their insides as they face each other. During new assemply or a rebuild, you pump a minimum of 10-12 shots of grease into this cavity. Heat from the variable speed belt/sheaves, transfers into the input shaft which in turn goes into this housing area where these bearings reside. That heat liquifies the pumped in grease within this housing. In other words, it becomes like a liquid grease bath for the 2 bearings. During operation of machine, don't grease this cavity everyday. Edited by AC7060IL - 06 Feb 2019 at 5:14am |
AC7060IL
Posted: 05 Feb 2019 at 9:28pm |
Sorry about saying flywheel. Yes, in my Gleaner parts book it is technically labeled; PLATE, clutch mount. Part # 71145055 for 77’ K2. Here's copies of parts book so you can get an idea of what I'm describing. Those hand written prices were from 8-15 years ago - so......? And if you dont' have a parts book, go to agcopartsbooks.com as a visitor to view the 860 input shaft. Everything you need to know is listed there. Here is a link to that page:http://agcopartsbooks.com/PartsBooksN/Viewer/book.aspx?book=agco/79005500. Well this link puts you at the top of the 860 parts page. So you'll need to scroll down to page 228, transmission - input clutch.
![]() ![]() Edited by AC7060IL - 05 Feb 2019 at 9:53pm |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8891 |
Posted: 05 Feb 2019 at 10:08pm |
There is an inspection plate on flywheel hsg you can remove and look at throw out brg. at least that's how my F2 is.
CrestonM
Posted: 05 Feb 2019 at 10:27pm |
Steve, yes this has the same cover you're talking about. I need to remove it and take a look inside.
CrestonM
Posted: 05 Feb 2019 at 10:35pm |
I'm a little confused...first you said about 1/2 pump per day, and I understand that part. My question is how do the two input shaft bearings (#5 and #8, right?) get grease? Is it just excess from greasing the hub that just heats up and liquefies? Or is there another zerk that I've missed and the operator's manual didn't show?
SteveM C/IL
Posted: 05 Feb 2019 at 10:36pm |
Warning....it will be very dark and messy in there
SteveM C/IL
Posted: 05 Feb 2019 at 10:41pm |
Does the K have the torque sensing spring can like an F2? If it does,you need to grease the crap out of it on the outer end to get the grease to the cams. And yes, it does pack the spring in grease but it will throw out the excess.
Edited by SteveM C/IL - 05 Feb 2019 at 10:43pm |
CrestonM
Posted: 05 Feb 2019 at 10:50pm |
I looked at the F2/F3 parts book, and on the non-hydro model it shows the "Spring and Cam Assembly", but on the EIII/K/K2 book it just calls it "Spring Assembly". I didn't think the 860 had the torque sensing mechanism like the later models, but others will confirm.
AC7060IL
Posted: 06 Feb 2019 at 5:17am |
AC7060IL
Posted: 06 Feb 2019 at 5:42am |
I also edited my prior reply about replacing throw out bearing. The dis-assembly process is involved, but some items can stay intact if all are in good standing. Please re-read that post to see those edits.
If you view the names of items in the part's numbers, quantity, & description page, you'll see the term "plate" used quite a bit. For clarity with the AGCO parts counter people, we usually referred to things a little differently. Terms we used were as follows:
"Clutch Pak" is number 18, which book calls it "COVER ASY, CLUTCH." It contains a pressure PLATE. In all my years I never replaced a pressure plate. Instead a whole new Clutch Pak is used in a rebuild. "Clutch Disc" is number 19, which book calls it "PLATE". I think AGCO only offers a 4 button disc, but you can ask for a 5 or 6 button. AI's might be a 5 button? I would always take a 5 or 6 button over a 4 button cause I felt they grabbed better. "Flywheel" is number 21, which book calls it "PLATE, CLUTCH MOUNT". It is keyed & pressed onto the input shaft & held in place by a very thick snap ring. To remove flywheel from input shaft, start by removing snap ring. Then arrange, kinda in a circle, 3 6"x6"x12" wooden blocks on concrete in such a way to support only the outer round lip of input shaft housing. Using gravity & inertia, grab the input shaft with both hands & lift it, along with it's housing & flywheel, about chest high. So with flywheel facing the floor, drop it onto the 3 wooden blocks so as to allow the flywheel space to move when the outer edge of housing stops on wooden blocks. Done successfully, the flywheel will usually just slide off the input shaft in about 2-3 drops.
Edited by AC7060IL - 06 Feb 2019 at 6:32am |
CrestonM
Posted: 06 Feb 2019 at 7:26am |
Thanks for the photo in your updated post, as well as the term explanations in your last post. I'm beginning to think your operator's manual may be a little newer than my transmission, as my manual only lists what yours labels as #1 (for greasing), the input sheave hub, and it says lubricate every 10 hours, where yours says every 40. Mine takes grease very well (even though everything seems tight), and the book doesn't offer any clues as to how much to pump in, etc. The only advice it offers is to set the variable speed in full low range to gain access to the zerk. I've looked it over in person, and I can verify there are no other zerks there. Could be a production update later on? If so, I'm beginning to wonder if the grease I'm pumping in is able to work its way into the housing and grease the 2 shaft bearings. I guess it would have to travel through the spring canister then? Looking back at the 860 parts book and the Gleaner EIII/K/K2 parts book verifies most of the parts are the same (same numbers). But the K2 book DOES show that grease zerk on the transmission clutch housing.
AC7060IL
Posted: 06 Feb 2019 at 7:55am |
I have zero experience with any of the AC cotton machines. But just viewing your latest “still stripping” video, your 860 appears to have a Gleaner series II cab & 8 bolt wheels on drive tire’s final drive. So that tells me it’s production year should be 1977. Here’s why I think that. The Gleaner k produced from 1969-76 & the short back 1977 K2, all had 8 bolt final drives. The 1978-81 K2s had 10 bolt final drives. The earlier k only had a flat windshield. The curved windshield was used in all the k2s(series II). So a combination of curved windshield & 8 bolt final drive should be 1977??
No #2 grease zero on your 860? Maybe AC just packed the input shaft’s housing with grease at factory? |
CrestonM
Posted: 06 Feb 2019 at 10:31am |
I can understand your thinking on why it would be a 1977, and I know it's a little confusing (I've wondered why they have the later-style cab myself) but I know for sure it's a 1975 model, as I have a serial number list. Also, in 1976/77 they changed the design of the basket a little bit and made a few other changes on the machines.
Swinford's book shows two early 860s, and they are either 1973 or 74 models, and they have the curved windshields. My serial number is 3091, making it 1975, and my parts machine is a 1974 I believe. ![]() Only thing I've thought was maybe the cabs were from an M/L (hence the curved glass) and not actually a K? It is built on a K/K2 chassis, though. As far as the housing not having the zerk, however...I've noticed the spring assemblies between the 860 and K2 (serial 24201-27200) have different numbers, but virtually all other part numbers are identical between the machines, and the 860 book is from 1978, the last year of production, so I guess they didn't add the zerks like they did on the K2? You may be right about the housing being packed with grease. The book doesn't mention it, but I may find out on disassembly.
Edited by CrestonM - 06 Feb 2019 at 10:52am |
AC7060IL
Posted: 06 Feb 2019 at 12:48pm |
[QUOTE=CrestonM] Swinford's book shows two early 860s, and they are either 1973 or 74 models. My serial number is 3091, making it 1975. Only thing I've thought was maybe the cabs were from an M/L (hence the curved glass) and not actually a K? It is built on a K/K2 chassis, though. My thoughts exactly. Yes, the M-L were introduced in that era. Is there any older dealerships in your area that might know about it? Even on this forum, seems most of us have little exposure to these machines. Any chance there might be a cotton pickers forum elsewhere? I’d recommend that you disassemble it before ordering any parts. And if you find yourself in a jam, please PM me & I’ll try to help talk you thru it. |
CrestonM
Posted: 06 Feb 2019 at 1:44pm |
We do have an ex-Allis dealer about 30 miles away, and while they can get parts, the guys that worked in the shop during the '70s/'80s are gone, and the only guy that's there now was fairly young back then, but I need to call him and see if he can remember.
I have an operator's manual for a regular "K" back home, I need to look and see if shows 2 zerks on the input housing. Being as nearly all the part numbers are the same except for the spring assembly, there couldn't be much difference in the two transmissions. Edit: called the guy, and while he had never worked on a K (most combines around here were C/G) he said on the G’s they often took out the zerk on in input housing and put in a pipe plug. They’d pour grease in the cavity and replace the plug, because a grease gun could build up pressure, blow out the seals, and get grease on the clutch. He said the bearings on an 860 that the input shaft ride on were packed with grease as you suggested. Not sure why they were, while the K had a zerk, but I guess that’s how it was. Edited by CrestonM - 06 Feb 2019 at 2:38pm |
AC7060IL
Posted: 06 Feb 2019 at 2:50pm |
Ok then... We're dealing with a model K. The K2 is slightly different on a few items. Here is what you probably need. It covers the repair of a model K's clutch. Does any of this look familiar?
![]() ![]() ![]() Edited by AC7060IL - 06 Feb 2019 at 2:56pm |
AC7060IL
Posted: 06 Feb 2019 at 2:55pm |
Heres a few more service pages for the Model K trans clutch.
AC7060IL
Posted: 06 Feb 2019 at 2:57pm |
I have several different year Gleaner K OMs. Early models (prior to 73’)show these 2 grease items;
- traction drive sheave hub(hub may not take much grease after initial greasing). - clutch throw out bearing. There is nothing else mentioned. |
CrestonM
Posted: 06 Feb 2019 at 5:25pm |
Thanks for the pages from the service manual. I'll print those and keep them for reference. Those photos do look like what I have on the 860, at least they correspond with the parts book diagrams.
Only thing I'm left wondering now is why the K book says grease the input sheave hub every 40 hours, and states it may not take much grease, but the 860 book says grease every 10 hours. It'll take as much grease as you want to pump in. Never seen any come out anywhere, so I don't know where it goes, unless it's into the spring canister some way.
