snap coupler turning plow |
Rod5300
Silver Level Joined: 15 Aug 2017 Location: Kentucky Points: 75 |
Posted: 29 Jan 2019 at 4:11pm |
I have found a 2 bottom plow that would fit my D 14 I don't really need it as I have 3 point plows to use but just like to have it for my 14 the plow seems to be in good shape but the hitch that fits in the snap couple bell is gone. How hard to find one of these and do they just bolt on.
I thank you for your comments on this post. Again thanks Rodd |
Rod5300
I figured to have some allis folks give me some insight on my plow question by now. I will ask this second question the plow is a 2 bottom no idea what tractor it was used on. I hoping it will fit my D 14
Again thanks for any help with these questions |
Larry in NC
Orange Level Joined: 09 Feb 2016 Location: NC Points: 1041 |
Usually you can find one on eBay. One is listed down, but a little high at $34.95.
Edited by Larry in NC - 29 Jan 2019 at 7:39pm |
Dave(inMA)
Orange Level Joined: 12 Sep 2009 Location: Grafton, MA Points: 2395 |
Always helps to post a picture in case there's something odd about the implement. But you should be able to put a two-bottom plow behind any tractor that will pull a three-bottom rig.
WC, CA, D14, WD45
john(MI)
Yes you should be able to bolt the eye on the plow. Just make sure the plow has the correct couplers for the latches. They are basically a Tee on the top. Some times the pin going horizontally got broke and farmers would just stick a bolt thru the hole. I believe there is a thread on Plows in the Knowledge base section, and it should have pictures. That would probably answer most of your questions.
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50581 |
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3464 |
It would be interesting to know what that originally came on. Has a degree of adjust-ability to it. Not necessary for a plow, maybe why the high asking price? I have one that is offset, never figured out what it was originally for.
Ted J
Orange Level Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18727 |
That is interesting, I don't ever remember seeing one like that. Somebody out here in Allis land knows what this one is for.
Yes, the plow one just has the two holes neither is slotted. |
wfmurray
I have wondered why A C did not put a safety on latch of snap coupler.Could have put a spring loaded pin under hook and saved there hitch .Dads plow flipped on D 14 and almost got him .Spring broke on hook. Had safety latches too.
