Electric motor experts |
Thad in AR.
Orange Level Access Joined: 12 Sep 2009 Location: Arkansas Points: 9285 |
Posted: 17 Dec 2018 at 6:42am |
I have a project that requires a 1 hp electric motor. I have one I found in my messy shop. I was going to scrap it because it has a lot of wires. I assumed 3 phase. After a close read on the tag it’s a single phase 120 or 240 v . It’s the proper 1725 Rpm. The tag says Dayton hazzardous area motor. It has no capacitor that I can see. Is the lack of a capacitor a problem? It starts with no load on this project.
I have another that is a face mount pump motor that would take more fab work to mount but it has a start and a run capacitor. |
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29667 |
Will need to do some research as to who made it or what it came off of as most likely due to a 'Lot of wires' was capacitor start. Capacitor start sets up rotational direction in most cases by applying a direction feed to kick the motor, without that the motor may just stall and overheat bumping F/R but not rotating.
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21567 |
Not all motors are 'capacitor-start-run' types ! so I'd say you're OK. Hazardous probably means it's 'totally enclosed' and won't send a spark outside to ignite 'fumes'. It'll have an internal fan to keep it cool. I have one 'somewhere' I used on a soil sifter 20yr ago...no dirt got INTO the motor. C-face motor typically used with gearboxes or pool pumps. I fabbed up an adapter plate once from 1.5" angle to form a a square 'faceplate', took couple hours.... hope this helps Jay
Thad in AR.
All those wires are either for high or low voltage. I already plugged it in and it runs perfect. I wonder if it may have a capacitor under the tail end cap?
I guess I have nothing to lose in trying it? |
nella(Pa)
Orange Level Access Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3086 |
The correct wires must be tied together for the 120 or 240 voltage. The motor can still run if they aren't, but won't have the power or burn out. If there is no wiring digram or if the wire aren't marked a good election or motor repairman can tell you which leads need to be tied together and which ones for the leads.
Usually there's a wiring diagram on the inside of the 'wire access' cover. It will show how to hookup for 120 or 240, fwd or rev AND if there's a cap or 2 . As I said , not all motors have/need caps to run.... those that do will have 1 or 2 'bump out' covers underneath live the caps. If there's no diagram, just google the make/model info of the motor....it's on the 'web' somwhere... Jay
Thad in AR.
Wiring all intact tag is there and like I said the motor runs perfect. I’m just wondering if it has a hidden capacitor or not and if it will have the power of a capacitor start motor even though it won’t start under a load? Sorry for the confusion.
Brian Jasper co. Ia
Sounds like a good question for an electrician
LouSWPA
Orange Level Access Joined: 11 Sep 2009 Location: Clinton, Pa Points: 24033 |
Im not an expert on electric motors, but how did you determine which wires to connect to get it to run? Is it possible that this motor was designed to be powered via external control system? With so many wires I am GUESSING that it is designed for multiple speeds or multiple loads, or multiple supply voltages, or some combination thereof. If it requires an external control system, that is where your capacitors would be. Jay is right not all AC motors use caps, but generally speaking I don't think those not using caps produce much torque
I am still confident of this;
Thad in AR.
Lou to has 8 wires numbered 1-8 and a green ground. 3 wires are tied together and capped and 3 wires make up the hot side then one is a neutral and one a ground. The wiring diagram is there for high and low voltage and rotation change for both. I have it wired for 120v CCR
desertjoe
Orange Level Access Joined: 23 Sep 2013 Location: New mexico Points: 13361 |
Hey Thad,,which of the 3 "numbered" wires are capped together,,and which of the other 3 numbered wires are going to the hot.. and which of the "numbered" wires are the neutral,,,?? I have a BIG, HEAVY 1 1/2 HP motor with the 8 wires and I never could find a legend to try to run it. Was thinkin on usin it on a compressor I ain't usin.
Thad in AR.
Text me tonight and I’ll tell you. You want high or low voltage? What rotation?
desertjoe
220 voltage and CW rotation. Mine is 1750 RPM also.
tadams(OH)
Orange Level Access Joined: 17 Sep 2009 Location: Jeromesville, O Points: 9685 |
Thad you have it running as instructed by the wires diagram, I would use it
shameless dude
o-k...whatcha building?
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41217 |
How does an induction motor start when it has no capacitor or ...1 answer Nov 1, 2016 - It's looks more like the old shaded Pole, with low starting torque that peaks before max RPM, ( no old jokes please) enter image description ... |
Coke-in-MN
Repulsion / Induction motors - low starting torque needed - no internal switch for capacitor start and no capcitor needed to run .
Used in fans - and other such uses |
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50636 |
Sounds like a normal dual voltage wired motor, to me. Once you wire it correctly, should be good to go, USE IT!
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78037 |
YEP.......... the 8 wires are typical of multi voltage, reversible motors.. You pick the rotation and 120 or 240 volts and then connect the wires to get that result. Capacitor not needed on many motors.......... your good to go.
Have done little with electric motors, just a few motor change outs over the years. Know a farm that has a Cap Start/run motor on a grain auger, the Run Cap is trashed and they do not want to buy one so the motor runs HOT as a forest fire all the time. In the Power Plant most all the pumps and equipment were 480 or 208 three phase, very little 240 or 120 single phase so had full staff of electricians to work them and keep them rotating the right way.
Edited by DMiller - 17 Dec 2018 at 6:35pm |
these are the numbers on the wires and how to connect on "MOST" motors http://apps.motorboss.com/connections/904983.pdf
JoeO(CMO)
Orange Level Joined: 11 Sep 2009 Location: Cent Missouri Points: 2694 |
Look on the Tag affixed to motor. Do you see anything referring to Capacitor Start or Capacitor Run. It may have centrifugal switch internally
Hazard area motors are most likely a fully enclosed motor and may have a remotely attached capacitor. Look on the tag---"MFD" field on tag will tell story What did this motor come off of??
Edited by JoeO(CMO) - 18 Dec 2018 at 10:52am |
HD6GTOM
If there is no tag on the motor, a trip with the motor to your friendly electric motor rebuild shop usually solves the problem. The boys there point out which wires to hook together for 120/240/rotation. At least that is the case at the shop I use in Creston Iowa. Good luck with her.
