D21 flywheel |
Allisplumber
Bronze Level Joined: 04 Jan 2016 Location: Wisconsin Points: 76 |
Posted: 26 Nov 2018 at 10:34am |
I’m looking for a new or very good used D21 flywheel, thanks for any help
NEVER green
Orange Level Access Joined: 28 Feb 2013 Location: MN. Points: 6502 |
Steel?? |
Allisplumber
Will be pulling farm stock class , but will be around 350 hp , 3000 rpms max , I know most all the guys I pull with still have the stock cast ones , steel would probably be the best way to go ?
ACFarmer
Orange Level Access Joined: 13 Sep 2009 Location: Ohio Points: 735 |
If your taking the time to put one in, put in a steel flywheel. Even at 3000 and below.
Making A living everyday farming with and working on Allis Equipment
NEVER green
You will sleep better at night with steel, wouldn t want to be libel for an injury or worse. I have a Rursch flywheel and 3 dick clutch, comes with rear engine plate slightly modified for low clearance bolts. Its for a 210, shaft same as a 21??? |
Allisplumber
Not sure if the shaft is the same but the d21 takes the same clutch as a 210 and 220 so I would think so , how much you asking for the one you have ? Thanks
NEVER green
How close are you to the twin cities? Im 40 miles west. |
Allisplumber
I’m east of Green Bay Wi , so your probably over 4 hours drive from me
NEVER green
Isshh ......... Just talked to Darrin and a new billet steel 12.5 crowler triple disc is 49, so 2500 sounds reasonable, at least I try to be reasonable. Just measured the shaft size it is 1 3/8. Let me know watchya think, there is others interested. Edited by NEVER green - 29 Nov 2018 at 4:20pm |
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4772 |
D21/210/220 can all use the same clutch when it comes to replacements. I think the D21 has more room in bell housing with the top mounted release fork though, when considering dual, or triple disc setups. I run a dual disc, and the casting bump where the release shaft passes through required some grinding.
