WC Head - What do you think?
mnickel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnickel Quote  Post ReplyReply Direct Link To This Post Topic: WC Head - What do you think?
    Posted: 20 Nov 2018 at 10:32pm
Hi All! I am new to the forum and to the tractor restoring hobby! I recently got this 1947 Allis-Chalmers WC and it was burning oil pretty good. I'm hoping it will be fine with a new set of rings and valves, guides, etc. I got the head off the other day and thought I would put these pictures out there to see what you guys thought of the shape of this head. As you can hopefully see from the exhaust valves, there doesn't seem to be much surface area contacting the valve seat, is that normal? Any advice you can offer would be greatly appreciated!
MDWilliams338 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MDWilliams338 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2018 at 10:43pm
If I’m seeing what I think I am from my hideous iPhone I’d put new seats in it all the way across while I had it down.The intake seats don’t look too bad but again,on my crappy iPhone 🤓
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2018 at 5:05am
Something looks a little amiss, on cyl#3, from the left.  Looks like it was running a little rich, compared to the others...Wink
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2018 at 6:30am
You need to check the guide/valve stem clearance as that can be a problem as far as oil burning.   As for the seats the best way to see what they are like is to lightly touch them with the seat grinding stone and see if stone contacts all the way around.  Of coarse clean head before doing this.   What does the cylinder boars look like?  My experience has been it's hard to get like new results by washing up old parts and reusing. Having said all that I will add if tractor has set for a long time the oil burning MAY improve some after working the tractor a few hours, keep us posted !!
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2018 at 6:34am
Its off.  I'd have a shop put new guides and seats in.
AaronSEIA
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2018 at 10:04am
Madison got this tractor from me and it was running OK but did burn oil.  Smoke was evident from the exhaust, but not to the extent of a "mosquito fogger"!  I suspect worn valve guides and probably worn rings and bores.  He got a nice WF from me earlier and has done a beautiful job on the restoration!!
Pictures, Madison!
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2018 at 10:10am
I have a WC shop manual on line in nine pieces in the directory:
http://geraldj.networkiowa.com/Trees
Gerald J.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2018 at 10:47am
If that head came in the shop before telling the owner what it needs done I'd ask what's the old "WC" going to do after the repair, is it going back to hard work or going into retirement and just see shows, that will be a big factor in what I do inside a engine or in this case the head.
Please tell us more about what the tractor is going to be doing.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2018 at 11:32am
If I had the head I would put in new guides which is easy and cheap. No need for new seats installed as the seats are not inserts now can be touched up with a light grind. The narrow seat is fine. All the valves need sparked out on a valve grinder. It looks like you only have two that were leaking. Looking down from the top of the valve guides it look like some carbon build up from a valve leaking hot air around the stem. Looking at two seats that are not shiny is more than likely where the hot air blow by was coming from. I would take it to a engine shop and talk to them about touching it up only what it actually needs to keep the cost down.
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2018 at 11:42am
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=umbrella+valve+seals+for+3%2F8%22+Valve+stems&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=BBC+umbrella+valve+seals&LH_TitleDesc=0
Most oil consumption is from oil going from crank case past the piston rings and burnt in the combustion process. Oil consumption is also from oil going down valve guides along the valve stems into the combustion process. Lastly oil leaks depending how bad can cause serious oil consumption. Have the head rebuilt and use 3/8" umbrella valve seals on both intake and exhaust valves. Click on above. You may need a complete engine overhaul with rings, pistons, cylinder liners, cam bearings, rod bearings, main bearings, and full gasket set. Click on below for parts cost etc. I just did my 1948 WC and it runs great and hasn't used any oil between the last two oil changes with 10W-30 oil and 100 hours between changes. Overhauls are not cheap but they are very rewarding. See picture of my WC doing its' thing this morning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2018 at 12:46pm
Welcome,
 I will go back and read your thread.
Yes we need tractor pictures!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnickel Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2018 at 7:24pm
Thanks for the advice! I appreciate it!
Yes, as Phil said it wasn't too bad, but since I need to replace the front crankshaft seal and a few gaskets that are leaking, I thought I might as well check the head and block. The block doesn't look too bad, but I'm not totally sure what I'm looking for. I can't feel a ridge or anything on the sleeves. I might post a picture later and we can see what we can come up with.
My plan with it is to try and fix the oil burning, fix a few oil leaks, get a new drawbar, and give it a new paint job. It won't be put to work much, but may go in the odd parade. See pics below.
I'll post some pics of my WF under a different topic!
Edited by mnickel - 21 Nov 2018 at 7:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2018 at 6:47am
Worth overhaul IMO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2018 at 7:46am
Any West-Allis built engine ( 125-138-149-160-201-W226-G226) never used valve stem umbrella seals of any kind.  OK on Fords and Chevys but not on an A-C.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2018 at 8:21am
To agree to Dr Allis and add to, I have pictures of heads I have been into with the umbrella seals and the extra wear from lack of lubrication caused by the seals. If you want to use the umbrella seals you can buy Chevy valves and guides that (might) work as it does in the Chevys.
Here are the seals
Look at the gap beside the stem
The guide holes are not all round and the one on the right was way oversized.
I put new guides in every head I had off an old tractor and touched up the seats and sparked the valves even if they looked good. I also sparked every new valve I put in to be sure they were going to seat properly. Not that I ever found a bad new valve but I have found other incorrect new parts. Parts are made by people and they do make mistakes from time to time. I sure do in any case. If your guides are sloppy the valve can not seat properly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2018 at 10:30am
In Dick L 's picture, someone put 2 umbrella seals in opposite directions on each valve. Sorry that's wrong. Put 1 on each valve with open end towards valve guide. After assembling valves, reach between valve spring coils with a small screw driver and lift the seal up to the bottom of the valve keeper and lock. This way the valve stem is exposed to the oil mist and gets plenty of oil for lubrication. Oil accumulates on top of the valve keepers and leaks down the gap between the valve locks and down the valve stem to the valve guide. On the intake valve, the oil goes into the combustion chamber and is burned. Also when the hot engine is shut down, oil runs down and accumulates on the back side of the valve and shows up as a puff of blue smoke upon hot restart. On the exhaust valve, some oil goes out the exhaust and some cokes up on the back of the valve upon shut down of a hot engine. Both intake and exhaust valves benefit from the proper use of umbrella seals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2018 at 10:56am
These engines were not designed for those seals. Probly dumber than rocks engineers since it was 80 years ago with the engineers being in the 30 years old. That was back when engineers didn't have the knowledge that the average mechanic has now. We all know anyone over 50 doesn't know which end is up. No idea what was in the persons mind that put two seals on these valves. Put the seals on and take the tractor out and work it hard ten twelve hours a day from spring to fall for ten years and see what you have. Being 80 years old and seeing all the things that happened because people were smarter than the dumb engineers of the 20's and 30's I personally would not put the umbrella seals on where they were not designed if I was planning on working the tractor.
PS: You might want to adjust the sarcasm meter up a tad.
Edited by Dick L - 22 Nov 2018 at 10:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2018 at 1:16pm
HAPPY THANKSGIVING!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnickel Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2018 at 1:23pm
Thanks for the advice! Happy Thanksgiving!
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2018 at 1:28pm
Phil48ACWC
How would you keep the umbrella seal from working its way back down by movement and gravity, and covering the stem from the oil mist?
Happy Thanks giving back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2018 at 4:30pm
With new umbrella seals, they fit tight to the valve stem and they do stay up. I use Comp Cams valve seals made for 3/8" valve stems and never had a problem. I've gone back to do valve adjustments and all the valve seals were up against the keepers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2018 at 4:42pm
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2018 at 4:56pm
Look at the 3rd picture from Dick L post. Notice the coked oil and carbon that built up in the exhaust port behind the valve. That's from oil running down the valve stem past the guide. It had valve seals improperly installed, per the 1st picture, causing guide wear and then the seals wore because there's not supposed to be stem to seal movement. The top inverted seal acted like a funnel collecting oil that came through the keeper and the gap between the locks allowing excessive oil past the guide causing the heavy carbon and coked oil build up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2018 at 4:59pm
The intake valve is not coked up with oil in the picture because it doesn't get hot enough.
