2800 engine in a wd45
Mufflerboltz2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mufflerboltz2 Quote  Post ReplyReply Direct Link To This Post Topic: 2800 engine in a wd45
    Posted: 07 Nov 2018 at 5:04am
Ok fellas, I use to post here a few years back but lost/forgot my sign in name and password.
So here it goes, I'd like to know what it takes to drop a 301 diesel into a wd45 chassis. Obviously I'd use a regular wd45 instead of hacking up a wd45d. Is there a special flywheel and adapter plate? I know the hood would need to be extended amd the radiator moved, does the frame to be added onto? I guess what I am asking is what do I all need to round up amd what to expect! Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 9:10pm
It is far from a "drop in"!
Parts are one thing.  Fabrication is another.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mufflerboltz2 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2018 at 7:40am
All the fabricated parts that need to be made are not an issue. I'd like to know what are parts that can be used like a flywheel/clutch setup. If an adapter plate needs to be made, that I can handle.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2018 at 5:31pm
You might call this guy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2018 at 7:01pm
Some people are just too talented...……...
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2018 at 8:53pm
yes that is a clean job, would the drive train ever hold up farming with it ?  would be hard not to over work with bigger implaments or not  shifting down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2018 at 10:10pm
So, to me it looks like he's using a WD45 diesel starter and maybe a WD45 diesel flywheel?? that has been modified to fit the 2900 crankshaft ?? The 2900 backplate has been reshaped and drilled to bolt up to the WD45 bellhousing. Frame has been lengthened. Hood has been raised taller. Don't know what he did for a radiator.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2018 at 1:29am
Here was a thread Lynn Marshall had at least another 7 pictures of the building of the WD65 Turbo Diesel... But alass they are gone.
mf440 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mf440 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2018 at 8:40pm
The wd45 diesel flywheel bolts to the 301 crank with no mods, same oil seal. Just lay a wd diesel engine plate on the 301 plate and mark the holes you need and the shape.
190xt llss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt llss Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 11:21am
It’s not that hard I did on a wd I have all the adapters and you use the wd starter. You can put the 201 or the 301 in with what I made. The hardest part was putting the bubble in the hood to clear the turbo
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt llss Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 11:26am
I might add I used the wd flywheel and pressure plate also
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 6:19pm
doing one right know , hard parts so far has been the steering , front shaft goes into diesel pump area , built jake shaft and made frames about 5 inches longer ,have pictures but need help getting on here , can text to someone thanks Steve
