Allis B Distributor
Elo76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elo76 Quote  Post ReplyReply Direct Link To This Post Topic: Allis B Distributor
    Posted: 19 Jul 2018 at 7:44am
When doing some troubleshooting, I pulled the cap off the distributor to look at the points and there is a plastic cap.  Does this cap just pop off somehow?  I didn't want to force it.  I have the delco remy.  This is on a 55 B.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2018 at 7:51am
After the rotor is removed, the dust cover should lift off. They can get  a little stuck over time.
https://i.ebayimg.com/images/g/vmAAAOSwcFVas6cG/s-l225.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elo76 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2018 at 8:20am
Thanks!
I have a few more questions.
1. The rotor that came with my tune up kit from Steiner does not look exactly like the one that's in there.  The existing rotor has and extra metal tab that goes off to the left.  I don't have a pic right now, but are they interchangeable?
2. Where do I put the grease that came with the kit?
Thanks Again
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elo76 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2018 at 11:54am
Can anyone help with the above 2 questions?
Gonna be tacking this in around 3 hours.
Thanks
1955 Allis B SN:126025
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2018 at 12:31pm
I would call Steiner and make sure they sent the right package. That smelly stuff does happen to the best of them now and then.  Also it my be the new ac-dc do all part now that works for many diff setups and nobody has experience with it.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2018 at 1:59pm
If it is a small pack of grease it is likely to lube the cam where the rubbing block of the points run. A little will do as you don't want it to throw into the contacts of the points.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 7:32am
Yeah, Steiner may have sent you an IGN kit for a MAG tractor, you would have to have told them your tractor has been converted to distributor
1968 D15D,1962 D19D
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 7:54am
I bought, from an old time A.C. dealer, a new rotor for one of my Allis's and it was different from the old one. The parts guy said that the old one was not the right one.
Dusty
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 9:03am
If the rotor fits the shaft and points in the same direction as the old one relative to the flat, maybe it's just a newer design.
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2018 at 2:05pm
The long hook on the rotor was to keep the engine from kicking back while hand cranking. I don't know if anybody makes them anymore.
 The grease goes on the distributor shaft where the contact is made to open the points.
