HD5 serial number location |
dyno
Bronze Level Joined: 03 Jan 2010 Location: Middleton, ID Points: 70 |
Posted: 14 Jul 2018 at 6:29pm |
Where is the S/N stamped on my HD5 Dozer? I looked on top of the back housing by the steering clutch cover but can’t see it.
truckerfarmer
Orange Level Access Joined: 26 Jan 2013 Location: Watertown, SD Points: 3183 |
It is on the back of the housing,cnot the top. You were within inches of it.
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41217 |
Left rear case on back side of casting about 1" down from top , if it is a HD5G with counterweight it may be covered over .
Also on plate on dash on right side of throttle housing but just above the brake pedal If a B then you should be able to see it on the back side - look above the draw bar housing straight up |
truckerfarmer
On my HD5B it is on the right side about an inch down from the top. Straight back from where the linkage goes down into the housing next to the steering clutch cover.
gemdozer
Yes the serie number should be on right side but if you have a winch or ripper the serie number should be covert.
dyno
Thanks guys! Hard to see with the winch in the way, HD5B 5764. Anyone know what year that makes it?
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50632 |
Per CH Wendell's book, 1949
dyno
Thanks Dave!
