Kit question
allispuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Topic: Kit question
    Posted: 24 Apr 2018 at 2:01pm
Called the local dealer for A&I products today about a rebuild kit for a D17 gas and found out they can get me one that they call a high compression kit. But they said it wasn’t any higher than a oem kit. My question is has anyone ever used it and what compression ratio might I be looking at since it’s listed for a wd45 D17 170 and 175
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 3:38pm
big difference between oem WD45 and oem 175
all the overbore kits that I know of are lower compression than the OEM 4" bore kits
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 7:24pm
If I were in the market for an engine kit, I would go to somebody like Jim Danforth that can tell you what CR the kit is, and get you what you want.
WF owner View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 9:05am
There is a really good thread about 201 and 226 pistons in the knowledge base section. Here is the link:
http://www.allischalmers.com/forum/followup-on-wd-wd45-pistons_topic114979.html
Edited by WF owner - 25 Apr 2018 at 9:07am
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 1:49pm
Powermax kits was the only one i could find with a high compression standard bore. But at the time they were out of stock (this was a while back) might want to check them out. All the agco kits are gone unless they ran a new batch in the last year.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 2:53pm
I would guess it's a 7.25:1 kit. Same as a D17.
Reliance/Powermax was the only guys making a true 8.25:1 175 kit. They don't have any more unless they made a new run between late last year and now. From past experience a year ago, it didn't sound like Reliance was interested in making another run
