wd45 parts wanted
WIAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WIAllis Quote  Post ReplyReply Direct Link To This Post Topic: wd45 parts wanted
    Posted: 18 Jun 2010 at 9:49pm
  I have a wd45 and the hydraulic pump wouldn't shut off.  Went through all the hoopla of resetting everything and still raised when the lever was down.  Wtarted taking stuff off and cleaning and looking, checking functions etc...  Pulled the hydralic pump off and whala.  There's the problem.  One cam roller on the pump worn in half and the pin ready to fall out.  Another is worn slightly.  Metal shavings all over.  That explains why the thing wouldn't release.  It has metal shavings packed into it.  So. does anyone have a hydraulic pump for sale...with the drawbar control on the back side of pump.  I would prefer everything hold control,drawbar control, and pump assembly altogether.  Just don't trust anything with the shavings.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 10:15pm
Try Sandy Lake Imp. 888-252-0656
Fidel513 mo. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fidel513 mo. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 12:07am
wiallis i don't have a complete pump,but if you find a good one i would be intrested in your old one for parts to complete my the pump i have in pieces.if you would sell the broke pump let me know. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote WIAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 12:55am
I can do that. worked fine and strong. Then was discing and out of nowhere wouldn't drop the discA good cleaning would probably fix the problem, but dont have much spare time to deal with it.  Much easier as far as time is concerned to just "bolt on" another unit and keep going.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 6:44am
I have some WD and WD45 pumps in Ohio.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WIAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 6:59am
how much are u asking? any leaks? good units?
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 7:48am
I will send you a PM with info. and pictures.   Richard
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fidel513 mo. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 8:10am
if all it needs a good cleaning and rollers plungers i could use it. i need the drawbar ontrol hold ing valve  and main body. i have the rollers and valves.
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 8:29am
i have one 20 miles west of dubuque 50.00$
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 9:37am
We have a few out there.  Would run about $75 + ship though.
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 9:51am
This dont happen verry often. I quoted the highest price of three offers.  O well
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 1:39pm
 Hey  guys  save those roller  Plungers , if  they are excellent,  last i checked  they were  $183 .59  EACH .      Tony
Kraig (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kraig (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 2:06pm
Go out to Peanuts (Jakel Tractor) near Humbirb, WI (between Fairchild and Neilsville) It's a tractor junk yard. I was out there this morning.
715-964-1702 or 715-896-0165
Kraig
7010,D17D,WD45,WD,WC,WC,B,
Gleaner K,60,66,72
