Calling B mechanics |
JW in MO ![]() Orange Level ![]() ![]() Joined: 16 Feb 2010 Location: South KC Area Points: 2670 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Jun 2017 at 8:24pm |
A friend called me about trying to get the shaft out of the transmission. The tractor is split, front seal is out, he says the manual says to tap the shaft forward to remove. He says he gave it a couple pretty good taps but nothing moved and when asked he said it didn't say anything about snap rings or clips holding it in.
Bill Long ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
JW, With my father we sold the B for the life of the unit. We did a lot of work on them but never had to do transmission work.
However, if you go to the AC G Generator Question entry above. In there you will find a reply by Gerald G. In it he has generously included a section of "Knowledge is Power" on the G-B-C-CA. It is a factory manual that shows breakdown of the B rear end. I did not read it but I am certain it will have the information that will be helpful to you in getting your B up and running again. Can't have my favorite "under the weather" Let us know how it goes. Good Luck! Bill Long
Ed&Sherry ![]() Silver Level ![]() Joined: 08 May 2010 Location: Owego, NY Points: 234 |
if he has an older B with a straight shaft and coupling on the end ,,there is a cotter pin holding it in place,,,,if its a latter modle they put a U joint in on the end of the shaft and I have not seen a pin in those [may have been broke before I get them
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
You are talking about the shaft in the transmission correct? What all has been removed from the transmission?
