620 oil levels. |
jeff n
Silver Level Joined: 15 Sep 2009 Location: new providence Points: 70 |
Posted: 10 Jun 2017 at 10:10am |
Hi I just got a 620 and I don't really know where to check the trans / hydraulic oil. I found a plug on top of the rear end but can't find a drain plug.i put a new hydrolic filter on and would like to change the oil as well. Any info would be helpful thanks .
Gary in Texas
Orange Level Joined: 11 Sep 2009 Location: Burkburnett, TX Points: 630 |
You have to remove the metal cover from the under side of the rig, runs from the engine to the trans/diff.
Then unhook the electric wire from the temp sending unit and remover the temp sending unit, at the front end of the trans/diff. That is what my books tells me to do to drain it.
Edited by Gary in Texas - 11 Jun 2017 at 5:10am |
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4783 |
My 720 has a dipstick on the bottom of the square head fill plug on top of the rear end behind the seat.
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3301 |
616 has street ell turned upright on the right side with petcock that is the high leval could depend on early or late 620, still drains in the same place as mentioned above post
jeff n
Ok thanks for the help I'll check it out in a few days. Can you still get any books anywhere for this tractor?
Allis Gal
Bronze Level Joined: 11 Sep 2016 Location: Farmington, MO Points: 14 |
you can download an operators manual here:
