Allis WC
drak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drak Quote  Post ReplyReply Direct Link To This Post Topic: Allis WC
    Posted: 01 Jun 2017 at 12:30am
Can any one explain what is the purpose of the stop bracket on the clutch pedal of my 35 WC ?
I often wonder what  could its purpose be other than to burn the clutch out Wink
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2017 at 6:00am
The one to lock the clutch disengaged?   Its for hand cranking to start.   Always always always start a tractor with the clutch disengaged.
AaronSEIA
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2017 at 6:02am
Also to disengage the belt pulley when hooked up to threshers and other equipment.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2017 at 6:29am
or burn out release bearing if run in disengaged  all the time on a bearing that has been in tractor forever  and grease is dried  up in it,
nonetheless ,still dead.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2017 at 6:43am
They had a grease zert in them.     MACK
drak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drak Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2017 at 11:55pm
Hi Aaron thanks for your advice, but why do you advise to start the tractor with the clutch engaged ?
yes its possible with the WC as a lock is provided, but on a B or C for instance there is no lock so its not possible to crank it with the clutch engaged, unless you have someone who can assist !!
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 12:04am
I've seen B's with it, mine included.
drak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drak Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 3:04am
Oh.......... looks like I need to eat my words Cry
I have a b and a C and nether have a clutch stop
Thanks Creston
what66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 6:41am
My 47 C had a clutch prop when I got it I took it off when I put a pump on the crank.
By the way, it keeps the clutch Disengaged not engaged.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 7:13am
Our '53 DW had one also.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 1:13pm
Pushed in is DISengaged and the tractor can't run over you if it happens to be in gear.
 Also, if you plan on long term storage, you can lock the pedal down so the clutch plates can't rust together.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 2:41pm
most hand crank tractors from all manufactors had a clutch release lock. It's there so when hand cranking it your not turning the input shaft to make hand cranking easier. In cold weather with the old 90 or 130 oil there was significant drag with the clutch engaged. If you had a belt pulley you had to lock the clutch down to start in any weather or you were trying to turn whatever it was attached to. I can tell you from personal experience you weren't able to crank it over and turn the whole sawmill at the same time.
drak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drak Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 11:42pm
Now that makes complete sense Dave
Many thanks for the clear explanation Clap
This page was generated in 0.046 seconds.
