Coolant |
K bockting
Bronze Level Joined: 18 Oct 2012 Location: MO Points: 135 |
Posted: 17 Mar 2017 at 6:06am |
Is Havoline Dex-Cool elc a compatable replacement coolant/antifreeze for the 301 diesels?
Have 3 tractors with coolant filters and 2 without. |
LeonR2013
Orange Level Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Read the spec. requirement, then look at what the anti-freeze will cover. I highly recommend that you get a PH balance test kit and check your anti-freeze twice a year. It may seem like overkill but what's that compared to a 10,000 dollar rebuild? Even with a water filter you need to do this at least once a year.
WD45Diesel57
Orange Level Joined: 20 Jul 2010 Location: Varna, Ont. Can Points: 646 |
i run John Deere Cool-Gard in my 7020, suppose to be a good anti corrosion anti freeze designed for higher horsepower engines! I don't take pride in using deere stuff but its priced decent and its good and it comes in big jugs pre mixed
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
AllisFreak MN
Orange Level Access Joined: 07 Dec 2009 Location: Minnesota Points: 1505 |
So you went for the big jugs, nobody can hold that against you...
WD45Diesel57
Nothing wrong with that lol
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29775 |
reminds me of a Bellamy Brothers song |
Wink I am a Russian Bot |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78127 |
DEX-COOL is a reference to antifreeze that has been used by GM for 10 years or more. Recently FORD has converted to this type antifreeze... normally it is ORANGE... If used in motors not designed for it, it will attack plastic and rubber parts... IT IS NOT COMPATABLE with the yellow "extended life" or the old GREEN antifreeze... DO NOT MIX. |
Composition
Color
Engine Materials
GM Guy
Orange Level Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1973 |
I would not run it. Its decent stuff, but does not blend well, and is rather picky.
Get Cat EC-1 equivalent. Specifically made for diesels, and is long life. Great availability, and its not JD. :) Available at any auto parts store, sold under Zerex, Rotella, etc. it will be red. |
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
K bockting
Thanks for the replies. That's what I researched also.
