400 AND 500 LOADER - differences
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: 400 AND 500 LOADER - differences
    Posted: 01 Mar 2017 at 7:26pm
Differences between 400 and 500 loader mounted on a D series tractor.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 8:59pm
I believe the 500's have taller uprights, and the 400's I have seen had oil reservoirs in one of the uprights to supply oil to the front mounted pumps. HTH
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 4:09am
The 400 Series came out first. Eg. 445, 414, 415, 417.
They were meant for Allis Tractors that did not have Live Hydraulic.
They required a separate Hydraulic Pump installed in front of the engine and connected directly to the front pulley.
The Loader Hydraulic Oil was contained in the L/H Upright.
The 2 Hydraulic Control Levers were mounted on top of the L/H Upright.
The 500 Series were meant for Allis Tractors with Live Hydraulic.
Eg. D-17 Series IV, D-19
There was no Oil in the Uprights, no Levers on the Upright.
Hydraulic Pump and Valves were original equipment mounted on the Tractor.
Gary
Fred
Just noticed this was your post.
You probably already knew most of what I posted !
Gary
Edited by Gary - 02 Mar 2017 at 4:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 9:07am
500's were made for the wider series side frames(180-190-200,etc). Spacer blocks were then used on narrower tractors with a 500 (D17-19- 170-175).
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 9:39am
Hate to rain on anyone's parade, but none of the above is accurate. The 400 had shorter loader arms, and a smaller bolster in the middle, they were for the smaller tractors up to a 19 because you could buy a 419 loader. The 500 series the loader arms were longer, the bolster was much heavier and fit the 17 on up and there was no spacers we have a 517 loader and it mounted direct. The hydraulics were available on both loaders as were the buckets, the frame width is the same. Either one could be ordered with front pump, etc, it was how the dealer packaged it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 10:40am
500 series loader on a 170 requires spacers per manual. HTH Tracy
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 8:30pm
So you could order a 517 loader for a Series II D-17, and install a front pump.
Tell me where you put the hydraulic oil for the loader and front pump.
Gary
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 8:40pm
Gary
My d15 serries 1 industrial has a 500 loader i was told it was that way from the start bought by a town new. The hydraulic oil goes in the right loader arm the hydraulic pump mounts to the front counter weight and is driven off the front of the crank shaft. I have seen the same setup on d14 industrial loader backhoe setups.
The control valve was mounted to the right loader arm as well.
Edited by Dan73 - 02 Mar 2017 at 8:42pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 9:03am
Kcgrain
Could you do me the honour of 'copy and paste' my post regarding the 400 and 500 Series.
Please add your correction of 'each' of my comments.
I am anxious to learn about all of the corrections.
Waiting for your Reply.
Gary
Kcgrain
I'm still waiting for your Reply.
I see you were on the Forum yest. March 3rd at 10:00 am , so you have had plenty of time to Reply.
Oh and be sure to tell me the source of your corrections.
My info all comes from my experience plus Original Allis Manuals.
Gary
and on again today March 4 at 10:05 am, and still no Reply.
- Eating a little Crow maybe ?
Gary
Edited by Gary - 04 Mar 2017 at 2:44pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 9:20am
Anyone know 'for sure' when the 500 Series Loader came out.
I expect it was 1964 when the D-17 Series IV came out with the 'Live Hydraulic'
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 9:26am
Gary
My d15 serries 1 is from 60 or 61 and it has a ts500 loader built by Henry for allis chalmers and Desertjoe has one on his d14 they only produced the d14 from 57 to 60 so the ts500 loader must have been made in that time frame. Joe might be able to tell you what the year of his d14 is.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 9:44am
Here is some info from the manual on 400 & 500 series loaders.
Maybe it will answer some questions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 9:49am
The ts 500 that is on my d15 has the curl cylinders on the top side of the frame not the bottom as shown in the photo above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 10:21am
This may clarify or may add more confusion. Here are two diagrams of the frames.
Apparently in 1965, the loaders may have used the tractor's own hydraulic reservoir rather than the frame tower on the D-19 and D-17 (series IV)?
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 10:29am
According to the parts book, the 400 loader could have the reservoir in the frame or not. The frame mounted tank was only needed with the front mounted tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 10:51am
I'm guessing the "TS" 500 loader is another breed of cat.
You say it was built by Henry.....does anyone know who built the A-C branded loaders?
I have some pieces from a New Idea loader that look similar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 11:00am
I think you meant front mounted pump.
Also, according to the manual, ALL 400 & 500 series loaders came supplied with the front mounted pump.
Why does the 1965 and up frame not have a reservoir when it would seem all the loaders used the separate front mounted pump?
I'm still wondering if the tractor's own reservoir was used in some cases, even with the front pump. Maybe to take advantage of the built-in filter system?
I bet some of you guys actually have these loaders and know the REAL answers.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 11:13am
Some models were built by Allis themselves. I believe the models with the tilt cylinders mounted under the loader arm are Allis built.
Wink
I am a Russian Bot
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 12:58pm
It think the loader was built in LaPorte. I know that's where you picked them up at. Hauled a lot back to Michigan.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 4:08pm
Allis Model 500 Loaders had the Tilt Cylinders under the Boom, same as Model 400 Loaders.
See attached original Allis Operators Manual Series 500 D-17, D-17 IV, and D-19.
https://www.amazon.com/Chalmers-Hydraulic-tractors-Operators-Original/dp/B00WDFTE3Y
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 4:50pm
Yep. that's similar to the manual my "General Information" page was take from.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 3:52pm
Looking for Kcgrain.
I see you are presently logged on.
Still waiting to a Reply to my Post .....................
Gary
Ken stanwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken stanwood Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2019 at 8:49pm
Hi, I know this thread is about 400 / 500 series loader but does anyone have info on the L200 loader? My spool valve is broken and I am trying to figure out what to replace it with.
