7045 Pulling Tractor |
AndyinWI
Orange Level Joined: 22 Sep 2009 Location: Blue Mounds Points: 416 |
Posted: 14 Jun 2016 at 11:06am |
The 7045 I just bought is going to be a full time puller. One of the first things we are going to do is split it and do something with the Torque Limiter. I know a lot of guys bolt them solid, some double spring them. Is one way better than another? I don't really understand how either is accomplished either. Any help is appreciated
Thanks! |
AC 7060
Bronze Level Joined: 06 Jul 2010 Points: 144 |
I had mine double sprung and it worked till just guessing 300 to 400 hp but I would skip that and just bolt it solid.
AndyinWI
How did you do it? Tap holes in the flywheel?
NEVER green
Orange Level Access Joined: 28 Feb 2013 Location: MN. Points: 6561 |
I took the backer plate to the machine shop with the heavy duty 6 pad torque limiter and they taped 6 holes in the backer plate. The bolts fit nicely into 6 holes into the torque limiter so it cant turn, its not bolted directly the bolts are stops. You should consider a steel flywheel, if it blows you would be libel. I had Rursch make a heavy one based on Uni ,
kinda spendy but I wont lose sleep!
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4783 |
Depending how hot you are willing to go, I have designed an adapter to mount one of my DB450 pumps on the 7000 series engines. The DM is a great pump, just not as much fuel can be squeezed out of them.
Boldt220
Bronze Level Joined: 07 Jul 2016 Location: New York Points: 6 |
Will the 2 speed speed take that kinda power. Or what do you do to it to take that power?
Orange Level Access Joined: 12 Sep 2009 Points: 19588 |
7030 clutch is 3-disc LOW and 2-disc HIGH design. The 7580 tractor is 5-LOW and 3-HIGH and fits in a 7030 tractor. You might be surprised how much HP the stock clutch will hold IF IT IS IN GOOD CONDITION WITH NEW SEALS AND DRIVE DISCS/PLATES and turn up clutch pressure a bit, maybe 240 psi?? Torque limiter has to be bolted solid either by your creation or a custom built drive disc.
AndyinWI
Dr.-
What about in a powershift tractor? Should I adjust the transmission pressure up a bit, or leave it alone? Hopefully I have enough power to break the tires lose and keep them spinning. We will find out Sunday night I guess. Haha |
No need to think about adjusting pressure up on either transmission, unless your HP gets much over 300.
The torque limiter is another matter.......
AndyinWI
According to Ed Guenther I am around the 500hp mark
Sure hope you've done something with the torque limiter on the flywheel.
AndyinWI
I drilled and tapped the end plate for bolts that act as stops in the holes on the 6 button disk
injpumpEd
Yes, your hp potential is around the 500 mark. But, running a lower gear will be easier on the drive train, and will not tap in to your available hp as much. Can't wait to hear how it goes tomorrow.
Joe(IA)
Bronze Level Joined: 12 Sep 2009 Location: United States Points: 99 |
Andy, make sure and do your home work on the details. All that hp won't help you if you are off on weight distribution, tire pressure, hitch height and down shifting timing. We pulled a black belly 7060 pd with around 400 hp in iowa and minnesota years ago and we didn't loose very often. We ran BF goodrich radials and those tires were hard to beat. Ran in 5th gear in 15k class and 4th in 18k class. Good luck!
AndyinWI
Well, I had a successful first run. I didn't get last place, and I was able to drive it on the trailer. The transmission slipped at 260' and I was done. The track was sticky and I never spun a tire. I ran 11.2 MPH in 3rd High. Any help with what to do with the transmission will be appreciated. I think I have found a parts tractor so that I can convert to power director over the winter.
Thanks, Andy |
