Hiniker 1300 cab |
Orange4ever ![]() Silver Level ![]() ![]() Joined: 01 Sep 2014 Location: Farmington, MO Points: 390 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Mar 2016 at 4:13pm |
Would one fit a 180/185?
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21795 |
Hiniker 1300 will fit a 180 or 185, but it had to come off of a 180 or 185.
Mine came off a 200 I think, what is the difference in mounting brackets.
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
Cab for a 190 /200 won't have anything under the back window. A little filler between the back window and the fuel tank is all there is. Put on a 185 youll have a large open gap between the rear window and the platform. The platform the 190 /200 cab bolts to it sits higher than your floor pan and you'll have nothing to bolt the cab to. I think they are the same width between fenders but that's about it.
lowell66dart ![]() Orange Level ![]() Joined: 10 Jul 2013 Location: Paulina La. Points: 964 |
If you have a good cab could you possibly find a 190/200 platform and mount that to your tractor?
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7493 |
There is no way a 190 platform will fit a 180/185! It is huge! As you can see, it is almost the same size as a bedroom door. The entire hydraulic system (lines, linkages, etc. would need to be relocated and you would still have a big hole in the bottom where the 190 fuel tank sits. ![]() |
Larry W. ![]() Silver Level ![]() Joined: 07 Nov 2010 Location: Luck, WI Points: 281 |
I have a year round I'm taking off a 185 this spring that will be for sale
