Snap Coupler WD vs D
JWingerter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JWingerter Quote  Post ReplyReply Direct Link To This Post Topic: Snap Coupler WD vs D
    Posted: 01 Feb 2016 at 6:41pm
Will an implement, say a plow, designed for a WD fit properly on a D14, 15, 17?
What would be the rub?
D17 Series III
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2016 at 7:06pm
Yes they will
The Allis Snap Coupler System came out in 1953 on the WD-45.
The WD-45 was replaced by the D-17 in 1957 with the same 226 engine.
The D Series started that same year with the D-14.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2016 at 9:51pm
WD-45 gas engine was a W-226 engine. The D-17 gas was the G-226 engine. They are NOT the same engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2016 at 1:51am
Not exactly. Most implements that are for the WD/WD 45 will need the lift links lengthened when used on the D series tractors.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2016 at 5:57am
Thanks Dr. Always thought they were the same.
If the D-17 is a 'G', does that mean it would fit in a D-14 or D-15 that have a 'G' Engine ?
This Chart doesn't show a 'G' 226 ?
Gary
https://en.wikipedia.org/wiki/List_of_Allis-Chalmers_engines
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2016 at 7:24am
Gary the "G" series was an enhanced 226 motor made for the D17, 170, 175 and "E" Combines plus later power units.
W201 was the original motor designed for the WC
W226 was designed for the WD45
I am pretty sure the designation was changed to differentiate from a Gas and Diesel motors, but that is my guess
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2016 at 7:26am
Imagine GM engine descriptions...small block....big block. The small block A-C engines were B-115,B125,G-138,G-149 and G-160. The big block A-C engines were W-201, W-226 and G-226. All were built in West Allis.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2016 at 9:21am
You need to take a look at earlier SC implements when attached to any D-Series, just to ensure the geometry is right throughout full movement of the implement.
The SC blade for example can hit the drawbar hanger bolt heads when fully raised on say a D15II. These rear bolts can be removed and the hanger moved sideways by loosening the front bolts and then locking them in-place, or remove the hangers completely.
I take it easy when raising my blade(s), knowing the hyd pump will relief cycle when the blade tongue/frame tags the bolt head, or just not raise it fully as I run tall rear rubber and have good clearance.
Raise anything you hook up initially, slowly, watching/listening for any interference; some of this SC stuff was cobbed up over the years and anything you feel may not be OEM would warrant a picture posted here for folks to chime in.
