Allis 5015 engine replacement
cj93z View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cj93z Quote  Post ReplyReply Direct Link To This Post Topic: Allis 5015 engine replacement
    Posted: 04 Jan 2016 at 5:11pm
I bought a well used 5015 4x4 at auction early in 2015.  It was smoking a bit but ran good.  Unfortunately it suddenly started knocking and before I could shut it down it blew the left side of the engine with the oil pump/filter right off.  Looks like the #2 piston/rod had a problem :(  I've been looking for a replacement engine.  I can't afford too much because like I said the tractor isn't in the best shape but everything seemed to be working ok before it blew.  I'm will to travel a few hours from NJ.  Will an engine from another tractor fit without too much trouble?  I don't mind some fabrication.  I've seen a couple 5020s for sale but I'm not sure how hard that swap would be.  I really like this 4x4 tractor and it was going to replace a couple of my smaller simplicity garden tractors.
Thanks in advance for any help or advice!
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2016 at 6:39pm
will this be of any help too see
what they used them in
 Toyosha 1.0L 3-cyl diesel
http://tractors.wikia.com/wiki/Hinomoto
http://www.tractordata.com/farm-tractors
/005/0/5/5055-bombardier-mpv-20.html
/000/1/9/191-allis-chalmers-5015.html
                               B:-)   Dnoym
JacksAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JacksAC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2016 at 7:56pm
If you will be selling the simplicities can you let
me know .
Thanks, and sorry to hear you bought a lemon
Auction equipment is at best a roll of the dice.
Regards:
Jack Beale
831- 710-5768
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 9:57am
cj93C where you located in NJ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JacksAC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 10:04am
We are located in Happy Jack Arizona
May have to pack a lunch or two.
Probably need sleeping bags as well
Never been your way, may be some day
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 10:47pm
Your post read like you were from NJ.  I'll git' out to AZ one of these days to see my buddy Armand...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2016 at 5:06am
I think the same engine can be found in a MF 1010... Or maybe the 1020...
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2016 at 9:32am
Steve
I think the wrong guy replied to your post.
Gary
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2016 at 12:15pm
It would seem to me that once a company gets acquired by Hitachi
the end is near.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cj93z Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2016 at 12:18pm
I'm in Blairstown - not too far from you at all.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2016 at 12:34pm
Stick you a 125 in it. Easy to find, cheap to fix and find parts for and they everywhere. Just have a machine shop make you an adapter plate and might need to do something different with the clutch. Rick Corder can prolly help you figure that part out. Be alot easier to get started in them cold Winters too. Just a thought.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote cj93z Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2016 at 12:44pm
I have a good buddy with a machine shop so that's not a problem.  I heard that the motor is part of the frame on these machines so I don't know about that part.
What exactly is a 125? ;)
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2016 at 12:48pm
Just need to use your imagination and your buddy's machine/fabrication skills. It will fit I'm sure. Just gotta take that leap of faith in yourself. Good planning and research helps alot. A 125 is an engine found in most B,C,CAs.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2016 at 5:20pm
Yer right Gary. I didn't realize it was the other guy that posted back. Wow! cj93z you're 20 minutes away via Rt94!  Good to know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2016 at 6:29pm
That whole tractor would need to be butchered to try to make it run with a 125 4 cylinder engine.  Making it LOOK like a tractor after that is another adventure!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2016 at 6:43pm
Go ahead, butcher it.  I saw a 5015 re-workd to look like a D21, that was neat.
Is there a photo of that somewhere on this site.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cj93z Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2016 at 12:22pm
I don't really mind butchering it because the overall condition is a little rough anyway.  Just need to do it for around $1000 or less, that's the tricky part.  If I'm going to spend more than that I might as well sell it for parts and find another one in better shape.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2016 at 5:36pm
If you are set in re-doing it, if you start with say a kubota motor, you might find one that'll bolt right up, I don't know.  My bet is that they prolly had a standard bolt pattern for several tractors, like the massey and hinmoto...
