HD4 hydraulic filter in tank?
 Rating: Topic Rating: 1 Votes, Average 2.00  Topic Search Topic Search  Topic Options Topic Options
JohnF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnF Quote  Post ReplyReply Direct Link To This Post Topic: HD4 hydraulic filter in tank?
    Posted: 30 Sep 2015 at 9:52pm
I'm looking to purchase the hydraulic filter within the tank of an HD4. Anyone have any idea where I can purchase one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnF Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2015 at 10:19pm
I believe the Part number is 3031996
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2015 at 5:47am
I would suspect any local auto parts store may have one. Take your old one to them so they can cross reference it. I am going to do that with mine that I have to replace. norm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2015 at 9:15am
MINNPAR - Mpls Mn -- should have website for info
Click the part number or thumbnail image to see larger images, more details and related parts.
PART#MAKEDESCRIPTIONIMAGEWT (lb)ON HANDPRICESELECT
3031996ALLIS CHALMERS - CEELEMENT3031996 ALLIS CHALMERS - CE ELEMENT0.800CALL MINNPAR$81.21< name="Order" ="" value="3031996-1" style="margin: 0px; padding: 0px;">
†  Please contact MinnPar for current leadtime on this part
View Important DetailsCONTINUE SHOPPING    REQUEST FOR QUOTE / LEADTIME    PROCEED WITH ORDER
Edited by Coke-in-MN - 01 Oct 2015 at 9:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnF Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2015 at 2:46pm
Zero on hand. Why is an hd4 not in their list of equipment?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2015 at 5:30pm
are you sure it's a filter and not a screen strainer of some type - if in the tank i would say it's a screen .
remember that machine is 45 years old or so - MINNPAR was a supplier of parts for a lot of machines of AC industrial line and fork trucks .
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnF Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2015 at 5:47pm
Ya it's a steel canister with holes throughout. Inside there is pleated filter paper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2015 at 6:18pm
Try Ivan, at Sumerix Equipment. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2015 at 11:25pm
A steel canister with holes  - and pleats - I will almost bet a $1 it't a suction strainer .
 If it was a filter it would need a solid outside to build pressure to force oil through pleats .
A filter would be on return side of system - a strainer on intake to pump . .
 Check and i think you will find the pleated material is a metal screen .
Cannoncollector View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cannoncollector Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2017 at 12:28pm
John F...I know this is an old post but , I was looking for one also to find this filter not available anywhere right now, but matching up its size exactly, but a larger center hole is Wix number R44F03C..this filter is a 30M screen and is a hydraulic filter..I just used a larger washer above the spring for installing.
