Replacing hand clutch |
worldchamp19
Silver Level Joined: 01 Nov 2013 Location: Vandalia, MO Points: 127 |
Posted: 24 Sep 2015 at 8:53pm |
What is involved in replacing the hand clutch with section of a WD45 with the gear box from a WC?
Thanks |
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3744 |
are you talking about just removing the hand clutch to prevent slippage?
you can bolt the clutch together by using 2 of the pto drive gears, or you can use a splined coupler from a wc trans to pinion shaft. several different ways to accomplish this. think you could probably bolt the clutch together if you weren't wanting to also lose weight I don't think you mean put in a gear box in place of the clutch? Edited by CAL(KS) - 25 Sep 2015 at 2:55pm |
worldchamp19
Yes I was meaning taking out the housing. I saw a picture where they took out the hand clutch housing moved the wd gear box housing to rear axle and in front put a wc gear box and it was connected to the engine.
CAL(KS)
wd/45 gearbox is one casting with the rear end. you would have to remove the torque housing ( hyd pump and clutch section) and replace with wc bellhousing and transmission, and couple it to the wd/45 input shaft then figure a way to seal the oil in.
a bunch of work to cobble something together that wouldnt be legal to pull anywhere. in my opinion, not worth the time and effort
Edited by CAL(KS) - 26 Sep 2015 at 9:10am |
mattb
Orange Level Joined: 11 Jan 2011 Points: 348 |
its legal everywhere I pull you can call me if you have questions six one eight three one four two seven four one
Orange Level Access Joined: 12 Sep 2009 Points: 19590 |
Your $$$ much better spent making the engine stronger.
