wd engine and marvel carb |
Justin82
Bronze Level Joined: 09 Sep 2015 Location: Pa Points: 7 |
Posted: 09 Sep 2015 at 8:30pm |
hello to all,
new member here that needs advice. I am running a wd motor with a 45 crank 4.125 flat top pistons and custom cam. I want to run 2 gear in 4500 class with 14.9x28 tires. should I stroke to 5" and cut the pistons or go with a different combo. The carb is a marvel with no ID tag, the air intake has a 1 5/8" ID if this helps. I built this motor 13 years ago and stopped pulling after 3 years until now so I cant remember the cam specs. The cam was done T.Richardson in NC. or SC. Thanks for all your help. |
BennyLumpkin
Orange Level Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
Any reason in particular you want to run second? Not paced pulling?
Central PA Allis Express
1934 WC254 1945 WF 1945 WC135755 1951 WD68085 1953 WD45-150217 1957 WD45D-230744D B110 |
Justin82
Yes some pulls are divided in to divisions and I would just like to trie something different.
Brampton 02 gt
Orange Level Joined: 07 Apr 2011 Location: Erin,ON, Canada Points: 321 |
I would think you could run second with that combo and spin out more often than not. Is it dying in second?
Justin82
Yes it will die out in second but will not die out in first even standing on the brakes. I am just looking for that extra hp in second but not go to radical on the engine.
Orange Level Access Joined: 12 Sep 2009 Points: 19596 |
What does a cranking compression test reveal for numbers??????
Justin82
I have not done a compression test yet but I will and let you know. Is there any way to tell witch marvel you have by appearance or measurements? When I bought it from an old allis dealer used I was told it was a gleaner carb. It also has electronic ignition from Denny's carb shop if that makes a difference.
mgburchard
Orange Level Joined: 14 Sep 2009 Location: Tennessee Points: 1123 |
Jt ran a usx series carb on his allis .
mgburchard
If you have a Facebook account go to allis wc @ wd pulling engines. You will find a fellow by the name of Brian Morrison there he does what your wanting to do but does it in third gear with 38 tire
Charlie175
Orange Level Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6351 |
Like a USX21 from a JD? You are being cryptic
Charlie
mgburchard
Like Oliver usx 29 think the deeres a 21
Justin82
Did a compression test tonight and 150psi across the board.
150 psi isn't much when it comes to pulling. A standard D-17 engine has 145 psi per AC Service book. A standard 170-175 engine is 170 psi or a little more. You could stroke your engine provided there is no ring edge in the sleeves, and get that compression up to 240-260 psi would help a bunch. Might want to consider using newer connecting rods from a late D-17 or 170 or have yours heat treated.
Justin82
If I get my rods heat treated what Rockwell do you recommend, and would I have to do any machining on them or would they maintain their tolerance?
