620 Front Hydraulics |
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7206 |
Posted: 11 Sep 2015 at 9:51pm |
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11570 |
Myron,
That's a pretty serious snow blower man! You'll move some snow wit' dat! |
macvette
Orange Level Joined: 13 Jun 2011 Location: nekoosa, wi Points: 1656 |
That was a real blessing in disguise.
DSeries4
Problem solved! One of the hose couplers on the snow blower was slightly shorter and would not fit into the remote all the way. I like easy fixes!
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3303 |
try hooking up your three piont cylinder and see if it works if it does the packing ont the piston in cylinder is blown
farmtoybuilder
Orange Level Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1453 |
You should have oil flow out each when you move control valve to either position. If you don't, Valve has a problem. Which is odd for spool type valve.
sparky
Orange Level Access Joined: 13 May 2011 Location: So. Indiana Points: 1464 |
Would one of the lines have unbled air in it? I don't really know but just guessing. Good luck.
DSeries4
Today I put the front mounted snowblower on the front of my 620 since I bought the package 5 years ago. However I have a problem. The hydraulic cylinder does not lift up the snow blower, it only pushes it on the ground more (raising the front axle off the ground). I tried switching the hose connections at the front of the tractor, but it makes no difference.
The remote ends on the tractor are brand new and the balls on the male connectors move when pushed (one squirts oil out, the other doesn't). It seems the lift control does not do any thing when you move it to the lift position (pull back towards the operator). It works in the lower position. However, there were times that the cylinder would not move when set in the float position. To me, it sounds like a problem with the connections at the front of the tractor. Any Ideas? |
