L3 Corn Head Help
JuniorFrm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JuniorFrm Quote  Post ReplyReply Direct Link To This Post Topic: L3 Corn Head Help
    Posted: 14 Jul 2015 at 9:12am
Looking for some advice. Been running an L3 for a few season now and looking to get a corn head. Would like to get an 8 row. I think it will be hard to find a clean gleaner head worth using. I've heard of guys putting JD heads on a Gleaner.
So, any thoughts? Can the L3 handle an 8 row. Anyone with any thoughts or experience in adapting a JD corn head to an L3? What model should I be looking at and any thoughts on adapting. Thanks guys!
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2015 at 9:22am
shouldn't have any problems with the 8 row except might get a little light on the back end, I added some suitcase weights on mine. I run 250 BPA corn @ 15% speed was showing 2.5 but felt faster tho, that's fun, sure fills the grain tank fast
Mike Plotner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2015 at 2:24pm
saw your post on Ag talk yesterday. I'd think you would be fine with it!
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2015 at 4:21pm
We ran an 8 row on a L3 for about four years. It worked well but you don't want to stop too suddenly as it does get a bit light on the rear. Most of the time in 160-180+ corn we could run anywhere from 3.2-4 mph. I alway thought the 8 row gave a better sample than the 6 row did because the machine was fuller. With all that said you should be fine with one. If you can find one. They are getting harder to find. If we wouldn't have upgraded to an R62 we would still be running the 8 on the L3.
ryan
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2015 at 4:41pm
We ran a. 8row on a L2 for years. It handles it well. Your limiting factor is your shoe. You can shell it off quicker then you can seperate it, if you get into real good corn ( which we don't often here). But 150 to 170bu corn an L will shell a lot of corn with a 8-30. I don't know how far you want to travel, but I know a guy in Northern ILL. With a real nice 8-30A corn head always been shredded, very very low acres.
     IG
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2015 at 9:57pm
We run an 8 row head on a late L2. It has RWA and a second fuel tank on the back, and we have never had any balance issues. We ended up adding a third cylinder to lift it (even though we have the bigger rams), but after we did that, we have got along just fine with it.
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2015 at 9:17am
Have a Black 8 row 30in for sale. Will fit an L-3. Located in Southeast Michigan, USA. Good condition. PM me if interested. Probably can find the original classified ad on this site.
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
Jwmac7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwmac7060 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2015 at 10:09am
250 bu corn with an 8 row on an L-3 would be more than a load...it would be like putting a 6 row on an F-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2015 at 1:18pm
Agree
This page was generated in 0.097 seconds.
