7040 fuel pump problem
critter View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Topic: 7040 fuel pump problem
    Posted: 03 Jul 2015 at 6:26pm
Last week our 7040 (about 6800 Hrs) wouldn't idle below 1000 rpm it would just stall, ever since we have had it the rpms would bounce around when running under 1000 rpm. Now the throttle seems sluggish slow to rev up and slow to slow down, after setting for about a week I fired it up and it wouldn't rev above 1000 no mater where the throttle was, shut it off and restarted it and the throttle worked although sluggish. It is the roosa master pump
I already changed the fuel filter and that made no change.
Seems to me something is getting stuck or sticky in the pump is there anything I can check in the pump or is it time for a rebuild?
Will it hurt anything to keep running it like this?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2015 at 9:45pm
could be some issues inside, but first, make sure it isn't sucking air in the supply side of the fuel system.
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2015 at 10:43pm
     You need to start at the beginning of the fuel system , the tank . Not in the middle .
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2015 at 12:29am
ed is the most knowledgable person on pumps here,but I would get someone to watch the fuel pump while you move the throttle, I remember years ago my7060 behaved like that and was slow to rev up and come back and it was the throttle /deacelarator linkage needing a lube. Throttle lever wasn't moving the fuel arm properly.The other thing about the idle is make sure the stop lever on the other side of the pump is getting opened properly by the stop button, sounds like its half closed.HTH
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2015 at 8:35am
One of the friction discs on the throttle of our 7580 broke the other day. If you held the foot feed down, you could raise the rpms, but the lever didnt do anything. I would probably run a pretty stout mix of whatever fuel treatment/snake oil you prefer, and see if that helped before you took off the pump, but you might be headed that direction.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2015 at 6:22pm
Thanks for the replies, the cable and linkage do fully move on the throttle and the shut off, I don't feel any soft spots on the fuel hose so I am pretty sure it's not sucking shut.
Started the tractor yesterday when it fired up it reved to 1500 then down to 1000 and you cant speed it up or slow it down. I think its time for a pump rebuild.
Edited by critter - 05 Jul 2015 at 6:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2015 at 7:25am
it sounds like the metering valve is sticking. Probably all gooped up with old fuel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2015 at 8:53am
Been setting with biodiesel?
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2015 at 11:13am
It sat for 2 years but I have put 300-400 hours on it since, don't know if the previous owners used biodiesel or not but we don't.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2015 at 11:34am
If it had sat, then it is gummed up causing problems. You're actually lucky it even ran at all. I've seen so many times with today's fuel, and tractors sitting for a year or two, not good!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2015 at 1:48pm
My combine sat from may 2012 to August 2012 and it gummed up bad enough to ruin the pump. Biofuel really blows.
Wink
I am a Russian Bot
