Simms pump on 426
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Topic: Simms pump on 426
    Posted: 29 Jun 2015 at 11:14am
I know this should be in pulling section, but this will get much more traffic, and it's not only applicable to pulling. Our pulling class allows up to a 12mm A pump, and the thought of grinding the side of my block to get an A pump to fit just sickens me lol! I really don't care for Simms pumps, but it will fit nicely, and I can get 12mm plungers for it, and since they did come on AC engines, it would be allowed. I just need a little more than the Roosa can provide. I haven't seen many AC simms pumps. Do they all bolt on like the DM on a 7000 series? Or do the earlier ones bolt on with the 3 bolt pattern like the Roosa adapter? I'm thinking of building a hybrid with the AC mounting flange, and a Ford pump since they are a simple pump and governor. The AC Simms seem to have more un-needed accessories. Thanks for the input, and I am looking for a cheap core to experiment with.
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 2:38pm
I have a 301 with a simms inline pump it has an adapter to bolt it up
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 7:29pm
Really no grinding on the newer blocks ed. Just touch the lower ear on the block side of the pump with a grinder. Otherwise im thinking you will need to remove oil cooler with either pump.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 7:56am
removing the oil cooler is already expected. I've got that planned already, and don't see any issues there. The early block like mine, has the casting bosses for all the plugs for the main oil galley, and to fit an A pump those require extensive grinding/removal. That is what I'd like to avoid. It would almost be easier to put all my parts into a later style block.
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 10:35am
When we hung the 1st A pump on my 210, we moved the pump out on the front cover to get around that casting so we didn't have to grind it all up. The sims that was on it first fit just fine in the factory location though.
Making a living farming with and working on Allis Equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 10:48am
did you use mark's front plate/cover?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 11:36am
We made the cover/plate ourselves but I think we might have gotten the gear from Mark. That's been a lot of years ago now. But doing it that way makes for a lot of room for lines ect. That set up is still on that tractor, just has 8000 series sheet metal on it now.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 12:40pm
Here is a factory install. Have the books with all the parts breakdown.
Edited by Calvin Schmidt - 30 Jun 2015 at 12:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 7:27am
thanks for all the input guys! But, I hurt the motor last night, so now if I gotta tear it all down, I may as well look for a later style block, then I will be able to bolt on an A pump, which will be needed for the class I attempt to run lol! Might be looking for some good used pistons and sleeves, along with a 7000 series style block. Also, haven't looked at the oil cooler area on them yet, but how does one eliminate the oil cooler? Plate and then external fittings? Prolly don't need to eliminate the cooler to fit the A pump, but I don't think I have an oil cooler for that series that's any good. Wish me luck in tearing into it today. Thanks again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 8:19am
5 hole Bosch injectors too?
Edited by peterson - 02 Jul 2015 at 8:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 8:30am
Or just drop in a 516 from a N7 and be done with it! Haha!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 10:22am
Ok, curious what a 5 hole Bosch injector cost,,,,,, maybe a dual feed line too??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 10:34am
Tips themselves are considerably less than the regular 4 hole tips. $25 rather than $90 bucks. Thing that costs the money is the machine work and other stuff to make them work, hold downs and return line kit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 11:16am
90 for tips?? lol!
AC 7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 11:34am
I have a p pump on a 7060 with the oil cooler still on
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 12:03pm
Thats what agco wants for them...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 12:04pm
Lets see it.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 1:06pm
max simpson did build a block off plate
https://plus.google.com/100961062008333654017/about?gl=us&hl=en
4297 Lamie Hwy, Charlotte, MI 48813
(517) 543-3467
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 1:18pm
Ed , I have a set of used pistons and sleeves with about 3000 hrs on them. They are large pin and in very nice shape. 360 201 5710 Kevin
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 4:55pm
Tips are reasonable then,, machining the body out to hold more fuel Prolly can get expensive
