180 185 trans
Orange4ever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Topic: 180 185 trans
    Posted: 24 Mar 2016 at 9:43am
Is the 180 and 185 transmission the same from the motor back?
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 9:57am
Pretty much. There were differences in the std PTO or hydraulic clutch PTO and low gear in older 180 transmissions was faster than later tractors, oldest 180's had smaller bolts on the rear wheel centers, but other than that, they are the same.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 10:15am
So the 200 RPM increase on the 185 accounts for the ground speed increase? Or was it more due to tire size (18.4x28)?
I've heard more than 1 person say the 180 was perfect with regards to the speed spread, and the 185 was just to fast
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 10:43am
180 and 185 gear ratios are identical in all gear selections, except for 1st gear on certain models. Seldom have I seen a 180 with anything other than 18.4 x 28's and the majority of 185's were the same way. Where I come from, 18.4 x 30's on a 185 is kind of special. Yes, 200 RPM makes a diff in all ground speeds, but whenever I worked on a 180, it got the extra RPM's automatically.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 1:20pm
it is amazing to me to see pictures of all the 38" tires on the web - this is what I thought would be a needle in the haystack.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 2:08pm
I think most were sold west of the Rockies....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 8:59pm
New question, is the transmission housings the same between the 180 and a 185 with hydraulic clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 9:03pm
The transmission/differential housing is from the hydraulic dipstick on back. The torque housing is from the clutch bell housing back to the hydraulic dipstick, and yes, it is the same for either PTO style.
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 9:49pm
Interesting how tractors were equipped or not depending on region , I guess. In Saskatchewan, Ive never seen a 180 or 185 with anything other than 18.4-30 tires. And Ive never seen one with three point hitch...Trev.
