AC Part Numbering System |
Ted in NE-OH
Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
Topic: AC Part Numbering SystemPosted: 21 Mar 2016 at 4:46pm |
How did Allis Chalmers pick part numbers. Was there a system for assigning part numbers?
DougG
Posted: 21 Mar 2016 at 6:03pm |
Always wondered that too,, so many numbers
den/southern illinoi
Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2079 |
Posted: 21 Mar 2016 at 6:28pm |
While I will not even start to say I am an authority on the number system, I have figured out a few things about it by having the parts # books and microfiche for parts #s.
First of all, the numbers started with 6 numbers such as 237496. After a while they ran out of numbers so all of these had a "70" added in front of them. They then started with a "71" in front of the numbers etc. I think that the last I have seen have a "74" in front of the numbers. Now there were groups of numbers assigned to various plants. For example the early numbers (and earlier there were a combination of letters and numbers) were assigned to the West Allis plant. The Independence plant where the Gleaners were built was assigned numbers starting with "71" so if you see a number such as 71107252, it is a Gleaner part. This number I just used is a beater blade for an A and/or a R. The items produced at the LaCrosse Works started with the 3??plus 3 more numbers on the parts (later the 70 was added in front of these 3s) and went up to the 7?? area. Now what I just wrote is not totally true as the Oxnard Works plant used the 4?? first 3 numbers on their 6 digit part number. And to cloud the explanation even more, the LaPorte Works started with the 5?? first 3 numbers. Clear as mud. Well I tried. I do know for example when I see a part number starting with 711, I know it is a Gleaner part. If it starts with a 5?? number then it is an item built at LaPorte such as an All Crop Combine and the other pieces of equipment built at LaPorte. Den |
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor. |
Posted: 21 Mar 2016 at 6:39pm |
The addition of "7" or "70" was when the Deutz thing took place. Gleaner combine numbers always were 11 or 13, they just added a 7 in front. For example, a model 7000 tractor power shift clutch disc was a 261212 from Allis. When Deutz took over it became 70261212.
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 21 Mar 2016 at 6:43pm |
I was told once the bolts, etc. started with a 9, older tractors.
Posted: 21 Mar 2016 at 7:06pm |
The "9" was used (from what I can tell) on boxes of items such as nuts, bolts, cotter pins, etc that came in and was used on a multitude of machines. Den
norm[ind]
Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
Posted: 21 Mar 2016 at 7:26pm |
it started as U-IN THE OLD PARTS BOOKS -U-3187- THE IT WENT TO 20 WAS ADDEDAS 203I87-- 71 WASADDED TO71203187 THEN AS YOU SEE IT TYODAY FOR THE NEW SYSTEM--THERE WERE DIFFERENT NUMBERS FOR DIFFERENT TOOLS LIKE MOWERS-COMBINES -ETC. WAS TOLD BY AN OLD DEALER DONOT REMEMBER WHICH IS WHAT ANYMORE- ASK BILL LONG FOR IT HE WOULD KNOW- MY 2 CENTS
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 21 Mar 2016 at 8:02pm |
When we started in the 30's the Allis Chalmers Number System for parts was as follows:
Tractor parts started with 2 Combine Parts Started with 5 Implement parts La Crosse La Ports started with 3 Bolts Nuts Washers etc started with 9 From here on in it is a guess Oxnard parts started with 8 Cannot help with Springfield Part numbers - that is where the Crawler Tractors were made That is the best I can remember. Now when I go to the AGCO parts book page I notice that the numbers for the old Allis Chalmers Parts start with 7 (?) then pick up the original Allis Chalmers numbers. Offhand I cannot tell how many digits the parts numbers had Hope this is some help. Good Luck! Bill Long
MACK
Posted: 21 Mar 2016 at 9:57pm |
Deutz had some #s that was almost the same as ACs so the 70 was added to AC #s. MACK
