AC Part Numbering System
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Topic: AC Part Numbering System
    Posted: 21 Mar 2016 at 4:46pm
How did Allis Chalmers pick part numbers. Was there a system for assigning part numbers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2016 at 6:03pm
Always wondered that too,, so many numbers
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2016 at 6:28pm
While I will not even start to say I am an authority on the number system, I have figured out a few things about it by having  the parts # books and microfiche for parts #s.
First of all, the numbers started with 6 numbers such as 237496.  After a while they ran out of numbers so all of these had a  "70"  added in front of them.  They then started with a "71" in front of the numbers etc.  I think that the last I have seen have a "74" in front of the numbers.
Now there were groups of numbers assigned to various plants.  For example the early numbers (and earlier there were a combination of letters and numbers) were assigned to the West Allis plant.  The Independence plant where the Gleaners were built was assigned numbers starting with "71" so if you see a number such as 71107252, it is a Gleaner part.  This number I just used is a beater blade for an A and/or a R.  The items produced at the LaCrosse Works started with the 3??plus 3 more numbers on the parts (later the 70 was added in front of these 3s) and went up to the 7?? area.  Now what I just wrote is not totally true as the Oxnard Works plant used the 4?? first 3 numbers on their 6 digit part number.  And to cloud the explanation even more, the LaPorte Works started with the
5?? first 3 numbers.
Clear as mud.  Well I tried.  I do know for example when I see a part number starting with 711, I know it is a Gleaner part.  If it starts with a 5?? number then it is an item built at LaPorte such as an All Crop Combine and the other pieces of equipment built at LaPorte.
Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2016 at 6:39pm
The addition of "7" or "70" was when the Deutz thing took place. Gleaner combine numbers always were 11 or 13, they just added a 7 in front. For example, a model 7000 tractor power shift clutch disc was a 261212 from Allis. When Deutz took over it became 70261212.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2016 at 6:43pm
I was told once the bolts, etc. started with a 9, older tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2016 at 7:06pm
The  "9" was used (from what I can tell) on boxes of items such as nuts, bolts, cotter pins, etc that came in and was used on a multitude of machines.  Den
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2016 at 7:26pm
  it started as  U-IN THE OLD PARTS BOOKS -U-3187- THE IT WENT TO 20 WAS ADDEDAS 203I87-- 71 WASADDED TO71203187 THEN AS YOU SEE IT TYODAY FOR THE NEW SYSTEM--THERE WERE DIFFERENT NUMBERS FOR DIFFERENT TOOLS LIKE MOWERS-COMBINES -ETC. WAS TOLD BY AN OLD DEALER  DONOT REMEMBER WHICH IS WHAT ANYMORE- ASK BILL LONG FOR IT  HE WOULD KNOW- MY 2 CENTS
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2016 at 8:02pm
When we started in the 30's the Allis Chalmers Number System for parts was as follows:
Tractor parts started with 2
Combine Parts Started with 5
Implement parts La Crosse La Ports started with 3
Bolts Nuts Washers etc started with 9
From here on in it is a guess
Oxnard parts started with 8
Cannot help with Springfield Part numbers - that is where the Crawler Tractors were made
That is the best I can remember.  Now when I go to the AGCO parts book page I notice that the numbers for the old Allis Chalmers Parts start with 7 (?) then pick up the original Allis Chalmers numbers.  Offhand I cannot tell how many digits the parts numbers had
Hope this is some help.
Good Luck!
Bill Long
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2016 at 9:57pm
Deutz had some #s that was almost the same as ACs so the 70 was added to AC #s.      MACK
