D15 II compensating spring?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: D15 II compensating spring?
    Posted: 09 Mar 2016 at 8:14pm
Not sure where the spring, part number 0227736-6 hooks to. It broke and fell out. Any help appreciated. Thanks tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2016 at 10:36pm
I have removed the gas tank and looked closely at everything in the area of the throttle linkage on 2 D14s and each series of D15.  I have not seen that spring on any of them!  It does not look like it serves any purpose.  I can double check my D15 II tomorrow, but I am 99% certain it does not have one.  All of these tractors run perfectly.
Edited by DSeries4 - 09 Mar 2016 at 10:37pm
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2016 at 6:49am
i paid bucks for one of them when I was resembling the D 15 II.  Could not figure out where it went or hooked to.  Duuu, I still don't but the throttle works fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2016 at 5:51pm
If its the one I am thinking of, gots a long tail and hook, fine wire, hooks from the throttle linkage, on the back side of carb, to one of the exhaust manifold studs...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2016 at 8:40pm
They definitely were on the D15 II's. I put a new one on this tractor several years ago. It is a small wire spring, fairly large diameter, it has a long end and short end. I can't remember where it hooked to. They will rust some and usually break at the long hook side.My manuals are at the shop. Thanks Tracy
Post Options Post Options   Thanks (1) Thanks(1)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2016 at 9:57pm
No, it's not the anti surge spring we are talking about.  There is a supposedly a small spring that is hooked to the throttle linkage under the fuel tank close to the instrument panel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 5:51pm
Dad pulled the panel under tank to clean mouse nest out of there and we have the same broken spring in there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 7:37pm
Mike can you tell what both ends were hooked to? Thanks Tracy
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 8:40pm
  their  should be a hole in the throttle from  gov. to carb-- fromm there it goes up to manifold stud abve it---if does surge - probably does not need it there are more out there without -than with them
Joe in Manty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe in Manty Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 9:46pm
I am in agreement with DSeries4, the question is about the compensating spring underneath the gas tank on the governor control. I pulled out my parts manual and see the spring, but no indication of what it is hooked to.
When I was restoring that area of my tractor, I had no spring either. There is a hole in the lower lever assembly (227730) for a spring but like Tracy asked, what is it hooked to. The spring must either help you pull the throttle up or help it throttle down.
The other spring being mentioned is the return spring (211320) that is attached to the choke control rod and hooked on a manifold stud. I remember when dad bought his Series 1 D15, I could start it on cold days with about half choke and with some engine vibration, the return spring would gradually pull the choke off.
Joe
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 11:34pm
Tracy we aren't sure where it was hooked ether. Sorry
This page was generated in 0.041 seconds.
