Luber-finer
dsmn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dsmn Quote  Post ReplyReply Direct Link To This Post Topic: Luber-finer
    Posted: 04 Mar 2016 at 12:59am
Having problems with Luber-finer on 7060 leaking, so after seeing information on here about just removing it, that is what I am planning to do.
My question is, do you just remove everything, disconnect the lines from the engine, and then put plugs in the holes where the lines went into the engine, or does there still need to be a line connecting these ports to maintain oil flow to any other area of the engine?
Thanks for any information.
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2016 at 3:54am
My 7050 just has the holes plugged coming out of the engine.
N6PETE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote N6PETE Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2016 at 5:52am
Run some line from those ends under the hood and install a spin on bypass on the side of the motor for easy access. I liked having the extra filtering capcity
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2016 at 5:58am
Napa sells a auxiliary filter kit like Pete is talking about. You order the filter housing/adapter, the filter that goes with it, and you can mount a new filter assembly in place of the old unit...
jorstad brothers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jorstad brothers Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2016 at 7:04am
the agco kit number is 74037180 to change it to a spin on.
remember plunder than burn
dsmn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dsmn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2016 at 9:21am
 Thanks for the replies, thinking as long as there is no other effects other than the extra filtering, that I will just put plugs in the holes for now.
 Just wanted to make sure that by eliminating the filter I would not be blocking oil flow to another area of the engine.
 This tractor only sees probably less than 100 hrs. a year, and not real heavy or severe conditions, so I am thinking with the two spin on filters on the right side, and change the oil once a year or every 100 hrs. it should be fine?
 I may look into the Agco kit for future use.
Thanks
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2016 at 1:25pm
Jorstad brothers - I just called my dealer and the bypass kit is no longer available.
Buying a filter at Napa or similar parts store or going to a wrecker seems the only route left.
What models had the spin on bypass filters? Did any of the 7000 series have them?
I know the 8000's did.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2016 at 2:42pm
You can buy spin-on filter add-on kits most anywhere. AMSOIL sells them for their micro filters.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2016 at 3:15pm
This may sound crazy, but what's a Luber-Finer?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2016 at 8:31pm
luber finers should not leak unless some one hasnt damaged the top
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2016 at 10:00pm
Well Creston,Luber-Finer is a brand name but they were most renown for big bypass oil filters which is why people call bypass filters...Luber-Finers. Kinda like the "Kleenex" thing. Lot of semis and construction equipment used to run them in the 70's&80's.Don't see em much these days.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2016 at 9:13pm
usually Luber-finer leaks are caused by people re-using the gasket too many times and/ or not getting things tightened down correctly.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 6:48am
Spin on by pass filter # is 777B. When the  gov. mandated removing sulfur from diesel & motor oils it really made by pass filters a moot point. Not that the oil is any better in many peoples minds, at least without the sulfur the bearings hold up a lot better.   Leon   Cmo
This page was generated in 0.142 seconds.
