stroker crank |
YT
Topic: stroker crankPosted: 13 May 2010 at 9:24pm |
With a 5 or 5.5 in. crank is there a stock type piston that will work in a 226.
Posted: 14 May 2010 at 6:19am |
I know a 5 inch stroke works with M&W 4.125" pistons from D17/WD45.....5 1/2" stroke is probably a bit much for the same piston.
YT
Posted: 14 May 2010 at 5:08pm |
Thanks doc, i was hoping that i could talk to you about this kind of set up but i've lost your phone #. Did you build any of those drop in kits you talked about earlier this year? Got a WD that we're turning into a full time puller and would like your opinion on some things.
mlpankey
Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
Posted: 17 May 2010 at 7:09am |
use a 400 cheverolet piston with a 1.6 compreshion height . you will have a 7.4 cr with a flat top. with a dome you could get some increase comp.ratio
YT
Posted: 20 May 2010 at 8:20pm |
Thanks for the info but interested in making alot more compression.I have 115 octane available so I was trying to get to 10:1 or more if possible.
mlpankey
Posted: 20 May 2010 at 8:24pm |
mlpankey
Posted: 20 May 2010 at 8:28pm |
I know of a automotive piston that will yield 13.1 with the stock rods and 5.5 stroke with a deck height of 12.656
YT
Posted: 20 May 2010 at 8:32pm |
I should have said up to 115. What octane does one need for a 10:1 CR? What about a 12:1?
YT
Posted: 20 May 2010 at 8:42pm |
Can you tell me what piston or would you rather not say on here.
mlpankey
Posted: 20 May 2010 at 8:55pm |
I have 4 used arias forged 4.125 pistons I will sell that will yield that cr with the 7.5 long rod . or you can use a 7 1/4 long 153 farmall rod and 5 3/4 stroke for 11.1 cr or the 7 3/8 allis d19 or buda rod with the 5 3/4 stroke yields 14.1 . I ran that combination for two years on 110 motor octane with no promblems. pistons shiped to you for 300. I can get cast 4.188 new pistons that will do the same cr ratios for the same price but have to add shipping.
Edited by mlpankey - 20 May 2010 at 8:56pm |
mlpankey
Posted: 21 May 2010 at 8:08am |
I thought pricing a used forged top quality set of pistons at half its new market price would get some interest . I guess I was wrong.
Lonn
Posted: 21 May 2010 at 8:21am |
guess so
Wink I am a Russian Bot |
mlpankey
Posted: 21 May 2010 at 8:26am |
cwhit
Joined: 12 Sep 2009 Location: Sigel IL Points: 1006 |
Posted: 21 May 2010 at 4:25pm |
Hold on, I know YT. He's not on here all the time but he'll check back in. I've seen the tractor that he's thinking about building up for a puller. I know he's serious about doing it right..That and he respects yours (mlpankey) and Dr. Allis 's knowlage on this subject..
mlpankey
Posted: 21 May 2010 at 4:54pm |
cwhitt I probably did jump to conclusions to soon . I get alot of calls and questions what can be done on a 1500 dollar budget . I laugh and say you only have a 1000 dollar budget for the bearings ,rings and gaskets eat up 500 easy.
cwhit
Posted: 21 May 2010 at 5:42pm |
If it was easy (or cheap) anyone could do it.
YT
Posted: 21 May 2010 at 8:43pm |
Sorry Mitch, Didn't see your last post till now. Still in the thought process of this build. Very interested in the parts and opinions you have. Just getting things sorted out.
Bullermanfarms
Posted: 14 Jan 2019 at 8:26pm |
Im going to try building a Allis WC for pulling and farm use. I was gonna put in a wd 45 crank, stock rods and slight cam work with flat top pistons but when i do the math I get 15 : 1 compression. I may have the math wrong but anyone got any advice to bring it down so i can still run pump gas and start it from the stock starter.
