Van Brunt Grain Drill
Steve A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Topic: Van Brunt Grain Drill
    Posted: 13 Dec 2015 at 6:26am
Any comments on older van brunt drills? I've been keeping an eye out for a drill to use for putting in wheat and buckwheat. Sandy soil and 20 years of the guy who leased it using no-till has rendered about 5 acres of a field into a sparse beach. Tried disk, broadcast and lightly drag last year but didn't get the results I wanted. Thinking a drill would give a more dense, uniform stand. What are the critical to look for wear on?
rob(ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rob(ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2015 at 8:36am
No-til sounds ideal for that soil. Something else going on here? Pull a soil test and check pH, likely needs lime, in my experience. Planter type will not matter if the seed cannot grow. What you did last year should have worked. As to the drill, check openers for wear and bearings, wear in pivot points on opener frames, seed box and flute condition, flute adjustment for tightness or seizure. Drills are basically all the same and fairly simple machines. Rob.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2015 at 8:45am
If it was notilled for last 20 years, it is time to get your plow out. Plow-disc and plant with any good drill.   MACK
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2015 at 10:35am
The old Deere Van Brunt drill I have won't notill. It doesn't have much down pressure on the single disk opener and it covers the seed with a drag chain, not a press wheel so seed to soil contact is not great. It did plant oats and alfalfa for me for years in tilled ground.
My farm notilled got mellow and didn't require extra down pressure on the planter after a few years of notill. But at this latitude notill delayed planting in the spring because of corn stover slowing the ground warming up to germination temperature and drying enough to not smear the seed trench. Tools in this soil wet make concrete.
There are notill drills made, the Van Brunt aren't them.
Gerald J.
Jwmac7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwmac7060 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2015 at 1:18pm
If my ground was no tilled for 20 years...you would never get anything to grow on it because it would be hard as concrete...take soil samples and plow it...then disk the wheat in
matador View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matador Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2015 at 3:29pm
We just replaced a John Deere Van Brunt drill ( I think an FB?) with an 8350 this spring. It was a good drill, but ours was just plain worn out. To fix it would have taken more money than it's worth. We don't no-till here, but I doubt it could have- it didn't have much down pressure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2015 at 6:15pm
Look at the discs, of course, and the fertilizer drive, of course, and also, at the bottom of each seed cup, there is a door, about 1-1/2" square, has a little latch that selects for seed size.  If the doors are rusted out, you will have seed leaking where it shouldnt, and most likely won't be able to set the door in the proper position...
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2015 at 8:28pm
I had one years ago it was a good drill.
VAfarmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2015 at 2:55am
We have one at the hunt club that we use for deer plots, we have planted wheat, buckwheat, soybeans, and Sorghum with it and it did a good job. I think we paid two or three hundred bucks for it when we bought it about 10 years ago. I wouldn't give much more than that for one. They are so old now I wouldn't be too surprised if some of the parts for them might be getting hard to come by.
Edited by VAfarmboy - 14 Dec 2015 at 2:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2015 at 4:19am
Thanks folks. The intent is not to use the drill "no till". Problem is the soil is so sandy-goes down at least 5 ft with yellow sand--and it's been sprayed enough, that there is not much organic matter left on the surface. Dad plowed it and the renter put it oats over alfalfa about 7 years ago. He took the oats off early, dry year and the alfalfa burned up. He went back to no till and beans the next year, and didn't get much out of it. Right now you can get hung up in the sand pulling a 6 ft disk. Nothing holding it together, and I'm trying to get organic matter built up in it without sinking a lot of cash in fertilizer. I'm going to play around with it for a few years, and if it doesn't improve, plant it to red pine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2015 at 7:32am
Plant it to Switchgrass or a mix of warm season prairie grass and leave it for 5 years. That will make big difference in organic matter in the soil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote matador Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2015 at 8:25am
Parts availability is a problem. We had a hard time finding the seed cups, the metal drop tubes (Had to get creative there), and even the disk openers. But, for the age, you see a fair amount of them in service still....
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2015 at 10:10am
I planted oats, wheat and soybeans with a 1938 Van Brunt drill, with high steel wheels, worked good.  Mine had double disc openers.  For soybeans after corn, Disc once with a heavy disc and plant.  Had a 51 Bu average using this method over the years with a high of 61 bpa.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2015 at 11:46am
My dad bought our John Deere Van Brunt drill in 1954.  It still works great.  15 inch Rubber drive tires and steel press wheels.
I have never had problems getting parts from my local John Deere dealer.
A neighbor was junking out a John Deere Van Brunt drill and I salvaged out the down pressure springs, tubes and a few other parts.
The discs and scrapers are still available from John Deere.
Bob J Wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob J Wi Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2015 at 2:59pm
Go to craigs list for Green Bay Wi. and type in
grain drills and you should see an ad for JD grain
drills that are cut down and rebuilt for ATV use.
I have seen his work and it looks like high quality
Go Packers
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2015 at 7:45pm
Any kind of tillage and you destroy organic matter. That's what tillage is for. Do you have a dairy or some livestock operation that has manure with straw (as opposed liquid manure) that might be willing to spread some on your land. That would be the fastest way to add some OM and improve fertility.
Otherwise try Sorghum-Sudan grass or other "green manure" crop and try vertical till or a light disking to work it in but don't plow or your wasting your time.
Trying to establish and grow a crop in sand without irrigation is pretty tough without good rainfall. Crop residue left from no till is the OM your looking for and managed properly will help your ground hold more moisture. One you plowed it the OM is broken and buried and decomposes quickly.
Fertilizer won't add OM to your soil and in sandy soil a lot of nutrients leach out of the root zone and eventually into the water table.
The best thing may be to plant the trees, some ground shouldn't be crop land
AGCO My Allis Gleaner Company
This page was generated in 0.474 seconds.
