7000 series cab
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Topic: 7000 series cab
    Posted: 01 Oct 2015 at 7:07pm
ok some are gonna say iam nuts  LOL but iam used to that my question is would a 7000 series cab fit on a 200 I missed a 8000 cab that woulda been nice but we have several 7000 cabs in the bone yard  I no there is no mounts, I can make those, the ac isn't a problem a 200 is side console already so controls aren't a problem  only reason not to go with a bigger tractor is its primary use is hay so we want to stay with the 301 just thinking out loud
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2015 at 7:14pm
What are you going to do about your fuel tank????????
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2015 at 7:35pm
do away with the two lower windows that are always so dirty you cant see through them anyway  and let the tank be the back like a year go round
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2015 at 9:35pm
Don't do that. Just get a fuel tank off of a 7000.
     IG
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2015 at 9:39pm
I put a 7000 canapy rops on my 190. Cut back out to fit over fuel tank. I think it should fit pretty good with some work.   MACK
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2015 at 9:47pm
I've seen a pic of one ona 190 tractor before, but don't know if it was just sitting on it or if it was accually mounted!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2015 at 9:52pm
8000 cab would be impossible to fit.  The steering wheel and dash are part of the cab, just like a firewall.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2015 at 7:04am
Dad put a 7000 cab on his 190 back in the late 70's. Allis was clearing out the old Accousta cabs because they started using the Accousta II cabs. There were 6 brand new cabs at a local auction and Dad bought one for $600. He wasn't very fussy how he mounted it. Used heavy rubber or rubberized canvas flaps to cover gaps at the front area around the dash and hood. He used the large end of rubber milker inflation cups stacked as isolation mounts. Moved the fuel tank back a few inches. Cut part of the back lower panel off the cab to make room for the fuel tank. It didn't look too bad and he always said it was a whole lot better than a heat houser. Wiper, lights and fan blower all worked when he was finished.
Edited by Lonn - 02 Oct 2015 at 7:08am
Wink
I am a Russian Bot
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2015 at 7:53am
I'd like to see a pic when you're through!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2015 at 9:32pm
ok whats the difference in a Accousta  1or 2 cabs and how do you tell the difference also the dash will come out of a 8000 cab its all steel
jorstad brothers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jorstad brothers Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2015 at 9:35pm
i have pics of one on a 210. im not sure how to ger it off my phone to here.
remember plunder than burn
matador View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matador Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2015 at 9:42pm
I'd use a 7000 fuel tank, too. I'd assume that would cut down on vibration by a lot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2015 at 10:09pm
7000 and 200 are the same tractor basically externally .
     IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2015 at 2:53am
Brad...Acosta 1, had boobs, Acosta 2 was flat chested
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2015 at 7:06pm
thanks shameless I was scared to ask so I went to tractor data and looked  now I see what you mean lmao kind of like the flat front matches the flat grill
This page was generated in 0.131 seconds.
