Cam bearing tool |
WC7610 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Sioux City, IA Points: 764 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Sep 2015 at 4:29pm |
Hi,
What are you using to remove cam bearings in a B engine? special tool? make your own?
Thanks
Most Bad Government has grown out of Too Much Government- Thomas Jefferson |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 53952 |
Search Youtube, here's 1:
[TUBE]http://youtu.be/NPlCr7PZCUc[/TUBE] Edited by DiyDave - 12 Sep 2015 at 5:35pm |
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
You can take the block to the machine shop, engine re-builder or maybe the local parts store will rent one like this one, it expands tight in the bearing and keeps the bearing from warping as it's pressed in place. Please look at the pics before you replace your bearing.
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3865 |
What ever you use don't forget to line up all the oil holes.
Yeah, thats why I'm asking. Got the block back from being sent away to a machine shop, they replaced the cam bearing- didn't ask them to do that but before I started putting the Cam back, I though I'd better check the alignment for the holes. One was 1/3 and the other two not even close
Thanks
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
I have the same kit Don has shown above, and it works great. Yeah it's a bit pricey, but you don't screw up bearings if you use it properly.
Still in use:
Use a long drill bit and redrill. MACK
bradley6874 ![]() Orange Level ![]() Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Take it back to th machine shop they screwed it up let them fix it if they miss it up again its there nickel not yours
O-no that's not good. You might do a test fit of the camshaft in the block if the cam fits OK, then I do just what Mack said, drill the holes through the cam bearings, clean the bearings from the drilling and retest the camshaft fit, if it's OK put her togather and don't worry about the cam bearing holes that are off. I'm just thinking out-loud. |
It they are already in, I'd try drilling, if you can do it through the oil gallery/block. Be sure to de-burr/countersink the inside surface of the bearing...
If you send it back, they may drive them back out and reinstall them. Then they will fit block too loose and turn with camshaft. MACK
Thanks for the info!!!
Thanks
AllisRocks ![]() Bronze Level ![]() ![]() Joined: 18 Aug 2016 Location: Wautoma WI Points: 11 |
I read this post too late and destroyed my first set of Cam bushings on my Allis Chalmers D14. (149 engine) I made this tool afterwards and it works great... about $5 to make from tractor supply. I lightly tapped them in. Maybe could press them in also using this tool.. The washers fit perfectly in the bushings.
![]() This is a picture of it on the used bushing. |
Gary in da UP ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
What Mack said X2
