Who made the articulateds? |
| Author | ||
Michael (WI)
Joined: 12 Sep 2009 Location: Larrabee, WI Points: 815 |
Topic: Who made the articulateds?Posted: 25 Jun 2015 at 11:22am |
I'm at an auction right now where there are several 8000 series and somebody looking at one of them claimed that it's got the same transmission (20 sp PD) as the Steiger.
He then went on to say that Steiger made all the large articulated for Allis like the 4w-305. I believe the 440 was a Steiger, but as far as I know the newer ones were engineered and built by AC. Or is there some possibility that Steiger assemble them for AC? |
| Sponsored Links | ||
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3519 |
Posted: 25 Jun 2015 at 11:51am |
allis chalmers made two series for Stieger - sold them the "bogies"
DougG
Posted: 25 Jun 2015 at 11:58am |
Stieger made the 440, A.C. made the others themselves
Edited by DougG - 25 Jun 2015 at 11:59am |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8715 |
Posted: 25 Jun 2015 at 12:55pm |
Yup. Steiger made only the 440 for allis, it is 100% steiger with orange paint and a cummins engine. However, if you run accross a steiger with bar axles, the axles and transmission are supplied to steiger by allis for those units. Darrel
Jordan(OH)
Joined: 11 Sep 2009 Location: Celina, OH Points: 1562 |
Posted: 25 Jun 2015 at 1:24pm |
AC supplied Steiger with some driveline components. Hopefully someone with better knowledge will reply.
DougG
Posted: 25 Jun 2015 at 2:12pm |
Yes AC did supply axles , trannys and Powerdirectors to Stieger later on , prolly the late 70,s early 80,s when they were looking hard for outside business;
grinder220
Joined: 11 Jan 2012 Location: Clinton Iowa Points: 2370 |
Posted: 25 Jun 2015 at 2:55pm |
If I remember right
it was the smaller 1000 series steigers, the last green ones before the Case IH models that had the Allis drive trains.Edited by grinder220 - 25 Jun 2015 at 2:55pm |
ILGLEANER
Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
Posted: 25 Jun 2015 at 3:02pm |
They have the AC 20 speed transmission in the stiegers in the 80s
IG |
JPG AUSTRALIA
Posted: 25 Jun 2015 at 6:39pm |
The 20 speeds in nearly every steiger is a spicer 10 speed box,same as the semi trucks use,early model steigers used these for 10 gears and the later ones got 20 by having a 2 speed drop box to get 20, powershift steigers were allison transmissions
bigal121892
Posted: 25 Jun 2015 at 7:47pm |
Except for the 20 speed transmissions supplied by Allis-Chalmers.
Mike Kroupa
Joined: 02 Oct 2009 Location: pierce, ne Points: 337 |
Posted: 25 Jun 2015 at 8:03pm |
Steiger wanted a couple models with bar axles and integrated pto's, this is where A-C came in and supplied the components. The ones that I've seen had an L10 Cummins engine. Can't remember about the dropboxes, but thinking they would've been A-C also. COUGAR 1280 is one model that comes to my mind. , Mike
bigal121892
Posted: 25 Jun 2015 at 8:12pm |
http://www.bigtractorparts.com/downloads/Stieger_Model_ID_thru1000.pdf
Starting on page 72
427435
Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Thanks(1)
Posted: 25 Jun 2015 at 10:19pm |
Short story. Two young engineers worked together at White Farm on the 4-150, and got to be friends and rode some motorcycle together. One went to Steiger and one (me) went to Allis in the mid 70's. We stayed in touch. Steiger saw the need for some tractors with adjustable wheel tread and live PTO. I got a call. Allis had the transmission and drop boxes (2 needed) to do that. Allis was also hungry for business, so we also took the 8000 final drive and made it into a "package" unit. End of story. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
ILGLEANER
Posted: 25 Jun 2015 at 10:52pm |
Good story I think I heard that one before. I hoped you would set the record straight. IG Edited by ILGLEANER - 25 Jun 2015 at 10:53pm |
427435
Posted: 25 Jun 2015 at 11:04pm |
Did I tell it over pizza in my kitchen?? ![]() Edited by 427435 - 25 Jun 2015 at 11:15pm |
Mark
gleaner1
Posted: 26 Jun 2015 at 7:50am |
1985 CR and KR Cougar 1225 and 1280's were
the only two models. It was a one year wonder. What is most interesting is that is this is the same time period that Deutz owned a stake in Steiger after purchasing the IH shares a couple yrs prior. |
ALLIS CHALMERS "The color is orange"
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3530 |
Posted: 26 Jun 2015 at 8:05am |
Interesting. I can't say enough, how much I enjoy reading about the rich AC history.
427435 - Thanks for sharing your incredible short story. I have 2 questions; 1. what are bar axles? 2. What were the hp ratings for these Steiiger/AC models? |
grinder220
Posted: 26 Jun 2015 at 8:36am |
Bar axles are the normal round axle shafts most tractors use as opposed to outboard planetary axles. Horsepower was 225 and 280. Like I said before the smaller 1000 series 1225 and 1280 models.
Mike Kroupa
Posted: 26 Jun 2015 at 8:47am |
AC7060, Bar axles are an acronym for adjustable axles. Up until that time Steigers had outboard planetary (non-adjustable)axles. 225 & 280 were the hp ratings. Also on a side not these particular models have turned into orphan's, with a lot of the A-C parts NLA. In contrast to the earlier & later models that used truck components, Allison trans. etc., Mike
jorstad brothers
Posted: 26 Jun 2015 at 11:22am |
there is a nice 85 kr1225 on tractor house with bars and a allis trans
remember plunder than burn
darrel in ND
Posted: 26 Jun 2015 at 11:11pm |
Hmmmm........got me thinkin. Darrel |
ILGLEANER
Posted: 26 Jun 2015 at 11:54pm |
Looks like it even has AC wedges on the axel. That would look pretty cool painted orange sitting between my 220 and 305.......hhhhmmmmm IG |
AC7060IL
Posted: 28 Jun 2015 at 12:07am |
Does anything in this photo look familiar?
m.tractorhouse.com/Picture/Index?listingId=9070889&categoryId=1108 |
AC7060IL
Posted: 28 Jun 2015 at 12:11am |
!!@! I did not realize my weblink was a group of photos, instead of just one...
Once the weblink photos appear, please scroll down to it's cab photos showing the gear shift console. |
