Allis C
ajec1947 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ajec1947 Quote  Post ReplyReply Direct Link To This Post Topic: Allis C
    Posted: 25 Jun 2015 at 8:28pm
I am trying to rewire an old allis c. The current wiring harness is on the side of the tractor where the starter rod and generator is. Is that where it should run or should it be under the gas tank?
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2015 at 9:30pm
The wiring harness runs under the battery box, through a channel on the right side of the tool box , where 1 #10 wire goes to the starter, then comes out under the gas tank and runs behind the air filter mounting bracket, behind the carb up to the generator ( 2 wires, 1 #10 and 1 # 14). 1 wire then goes to the terminal on the radiator shroud for the lights, and the last wire goes under the water neck, where it gets attached to bolt, and over to the mag. The Battery cable runs through the top of the tool box and out the hole next to the starter. Hope this helps. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
