185 suprise
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Topic: 185 suprise
    Posted: 08 Mar 2015 at 7:45am
I am finally doing some work on the 185 I got a year a ago and have used very little. I have the fuel tank at a radiator shop being cleaned and coated due to lots of crud inside. Here is my surprise from yesterday when checking the air filter. I think I will replace it! I like the AC logo on it.
Part time farming with a 1980 7060 and 1984 F3 hydro.
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 9:08am
We found 1973 filters in a 1855 oliver once. It wasn't 1976 when we found them either. Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 10:48am
Here is the air filter that I replaced on my 1966 D15 a couple of years ago.  Check out the date here...
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 10:52am
so if the tank was full of crud, I can only imagine what the pump and injectors are like!
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 11:52am
That isn't uncommon. People didn't spend money on things years ago like we do now. You blow filters out put them back in.
     IG
BradRisen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradRisen Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 2:44pm
Or take a clean five gallon bucket ,warm water, and some detergent ,and gently hand wash the filter ,let dry naturally, no compressed air while wet, then re- install,almost as good as a new filter.
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 3:08pm
     IG
Been there, done that ! Wink
Life is tough,but it's tougher when you're stupid. - John Wayne
ryanschott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryanschott Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 3:17pm
ill take a pic of mine my 185 has the original late 79 filter and its a 1980 model i have it cleaned spotless though. tractor has 2400 hrs i do believe
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 10:55pm
I'll replace an air filter vs replacing an engine any day of the week! Darrel
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 11:42pm
I send my filters out for cleaning, not that expensive and as long as you don't wait too long, they look good as new.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 6:15am
Good stories. My practice is to clean air filters and only replace when light shines through less than I think it should.
In regards to the fuel tank, the pump and injectors have only a few hours on them. Hopefully the sediment bowl and filter kept them clean.
Edited by Ben (MI) - 09 Mar 2015 at 6:23am
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 8:43am
Had a D19 that the intake hose was removed from the carb when we bought it. Put it back on and the tractor would not run. Had to remove the air cleaner from the tractor and destroy the element to get it out of the housing, was packed full of dirt. I think I was the first person since west allis to have that element out.
Edited by Butch(OH) - 09 Mar 2015 at 8:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 9:22am
Butch-I can imagine that good Ohio clay as dust packed in there like concrete!
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 11:37am
It's remarkable what some of these tractors have went through and still operate.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 3:05pm
     IG
I believe I saw at a farm show once a mechanism that hooks to the end of an air hose that has a small rotary thing one the end that you insert into the filter to clean it out. The rotary part spins really fast and shoots air out of the filter, removing a lot of the dust.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 3:45pm
Never heard of that type of service. Where do you send them?
Wink
I am a Russian Bot
