Another Motor Oil Topic |
David G. ![]() Orange Level ![]() ![]() Joined: 21 Feb 2012 Location: W Nebraska Points: 1738 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Feb 2015 at 6:52pm |
I changed the oil in 3 of my diesel pickups over the past couple of weeks and it got me thinking about oils and how they work. Truck #1: 1982 GMC w/ 6.2L diesel
Truck #2 1994 Ford 7.3L Powerstroke Truck #3 2001 Ford 7.3L Powerstroke I use Rotella 15w-40 in all 3 trucks and use Purolator filters on all 3 as well. I change the oil at 5k mile intervals. The thing that got me thinking was the condition of the oil at the end of the 5k mile period. I know diesel oil will get more black than gas engine oil. The oil in the old gmc will be as black as coal while the powerstoke engines oil will not be near as black. For that matter, I can check the oil in the gmc after only 50 miles and it is as black then as it will be after 5k miles. All the while, the powerstoke engines gradually darken. Most of the way through the 5k mile oil change, you can still see the markings on the dipstick through the oil, not the case with the gmc. The gmc is on its second engine since I have owned it. This engine has only 43,xxx miles on it. The oil looked the same way with the old engine which was wore plum out when I got it. So I cant say the powerstroke,s are still good and tight and the 6.2 is wore out. I've never saw a diesel engine turn oil this black that fast. The oil is so black it will stain your hands. It washes off with alot of gojo but using a rag wont begin to remove it. Another thought about oil, when I was in trade school one of the instructors had just bought a brand new (at the time) 1997 F-250 powerstroke. He and I got to talking about oil one day. He said he uses Texaco Ursa (sp?). I had never saw it on the store shelves anywhere and still haven't to this day. He said that the oil is just as clean after 5k miles in his engine as it was when he poured it in. Interesting. ... So here are my questions 1. What would cause my 6.2 diesel oil to be so black so fast? Would it have to do with emissions back in that era, more soot? The EGR system? 2. If the Ursa oil stays clean, does that mean the detergents arent working properly? on edit (not that this matters) all of these trucks might consume 1 qt. Of oil in the 5k mile period. Edited by David G. - 22 Feb 2015 at 6:57pm |
ryan(IN) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Bluffton,IN Points: 786 |
I think it is just the design of the older engines. My 7.3 idi in my 89 turns the oil black shortly after an oil change as well. It has 200,800 miles on what I think is the original engine.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
More blow by makes oil blacker. You may want to pull a sample the next time you change oil (let a little warm oil drain out before catching the sample). http://www.blackstone-labs.com/ The test kits are free. A basic analysis is $25 plus another $10 for a TBN analysis (good idea to do). The kits can be mailed back using the USPS. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
Mactractor ![]() Orange Level Access ![]() ![]() Joined: 20 Jun 2011 Location: New Zealand Points: 652 |
Very little oil circulating for a 379ci diesel. For that reason, I change every 3000 miles
Ok. Thanks for the comments. I suspected that the older engine had a lot to do with it.
Now what about oil that stays clean after 5k in a diesel? Is the detergent working? |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21905 |
The newer and more modern the diesel engine, the cleaner the oil will probably be.
And in the case of my idi International made the ring design sorta wacky and they produce more blow by than others.
ryan
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
I would think the opposite would be true. Detergents should be removing the grime and holding it in the oil. I was always told that "black" oil wasn't much of an indicator of the oil condition. I'll second the comment about having an oil analysis done. That will tell you more than anything. Since you are using a Purolator filter now, be sure it is the Pur One filter. That's their top of the line filter and it's a darn good one. |
