4W 305
Steve Bright View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Topic: 4W 305
    Posted: 15 Feb 2010 at 6:48am
Looking at a 4W 305 to buy and use on the farm, Would restore over time but will use on the farm this spring, I have never been around 1, 2 Questions: Do they have shift on the go? 2nd, would I be satified with the horsepower of the tractor? We will pull a 30 ft. Salford tool this spring with this tractor if we buy it.
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 7:23am
Howdy Steve,
I pull a 22 foot AC 2600 primary disk with 24 inch blades with my 4w305. It just plays with it! Don't matter the gear up to a point. Its the biggest thing I got. I am looking for a AC 1500 13 tooth mini till but, not found one yet. You are should welcome to come take  in some fun when it warms up here.
Kurzy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 7:29am
What about shift on the go? can you do that?
JERRY-KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JERRY-KS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 8:02am
Yes, the 4w305 has a Power director.  The shift is approx. 25% faster in HI side, then back to direct, just like other Allis tractors were.
Kevin(Alabama) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin(Alabama) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 8:36am
I have not seen a Salford tool (deep tillage). But I pull a 9 shank krause (22.5 feet) with the winged points, with my 4w305. It pulls it OK till I run uphill in some of this redland that has been in no-till for years, then I have to raise the plow up a little till it gets passed the hard spot, or it will want to spin alittle, but the the engine still don't know its back there, then I lower it back down and keep going.  I had thought about pulling two shanks off the plow till I used it and seen it would pull it alright. Only thing is my 4w305 has the 400hp Cummins in it, but I never run the engine at the max. rpms. I think the Allis engine with 305hp will preform for you alright with  the HP/weight ratio of the tractor.
"I would die a thousand deaths before I would betray a friend."...Sam Davis, Nov. 27, 1863.....DEO VINDICE
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 8:48am
The 30 ft Salford tool, for those who don't know is a minimium tillage too, It has 60 no till coulters, spring tooth harrow and rolling basket, it is a high speed tool, need to pull it around 8 MPH. Pulled it last year with a Versatile 936. I've had several calls this morning saying power will not be an issue, proper weight, and drive line will be the major concerns. If anyone has anything I should be aware of please feel free to tell me. Versatile handled it very well, no on the go shifting makes it more difficult turning on the ends or crossing a waterway, thats why I need to know about the shift on the go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin(Alabama) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 10:03am
I think you should be alright then. I was not sure if the Salford was a deep tillage tool. Tires and added weight should make a differance in slippage if it that does become a problem. The 4w305 to my knowage had no power shift. But like Jerry said it does have the eleltric hi/low on the go shift. If you do try to change gears on the go while pulling a load it will stop in its tracks when you hit the clutch.
This page was generated in 0.484 seconds.
