51' G engine
kyvfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kyvfarmer Quote  Post ReplyReply Direct Link To This Post Topic: 51' G engine
    Posted: 10 Feb 2010 at 8:30pm
New engine needed, My 1951 G blew a rusted seal while cultivating this morning,It was so cold this morning (37deg)didn't notice the overheat .Poo the seal and crack the head.This is my daily cultivating tractor.  I need to repair ASAP.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 8:44pm
Not trying to be funny, but what is a rusted seal? Head gasket maybe? Are we talking about the L-head continental engine? How bad is it cracked? If the block is OK, you may be able to get a good shop to weld the flat head, then machine it to take out any warpage. Then you would only need to order a head gasket from Tony Carbaugh or any of these other fine folks on here. I'm sure they would sell you an engine if yours is worn out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kyvfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 8:58pm
It was one of the steel seal from the block ,aparently have a pinhole .I bought the tractor for daily use and have serve me for the last three seasons.Theres a visible crack on the head.
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 9:00pm
soft plug maybe
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 9:07pm
I see. Core plug on the outside of block. Also called freeze plugs. I'm guessing you can see the crack from outside? Have you taken the head off yet? Did the tractor quit with you, or did you notice it and shut it down? You can remove the rusty core plug and measure the hole. Most parts stores can get you replacement plugs. If you have a NAPA around there, they can order gaskets and such also, but I have had great luck with Tonys' tractors. He's in Oregon, and he can get me parts to GA in 2 or 3 days. He has most of this stuff in stock too. NAPA would probably take that long, and might cost more too. All this depends on how much else is wrong with it. Pull the head off and see what you have.
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 11:13pm
Have some reconditioned heads Ia 563 652-2949
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 9:50am
I've got a G with a welded head.  I didn't really notice it until last summer it seeped a bit near the water outlet.  There is a hairline crack next to the weld, I put some JB weld on it and it seems to be holding fine.  Dunno when it was welded, but it looks like it was donkey's years ago.  The head in that area is really thin, I'm surprised it worked.  But I guess it proves it is possible to weld one up.
cheers,
Creek
JohnDNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnDNY Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 6:04pm
Cultivating at 37 degrees? Wow. Keep warm
This page was generated in 0.884 seconds.
