how do I increase the rpm |
Post Reply | Page 12> |
Author | |||
firephight
Orange Level Joined: 16 Sep 2012 Location: st.louis Points: 320 |
Posted: 18 Jun 2013 at 4:11pm |
How do I go about increasing the rpm to 20º over stock in a wd45
Sponsored Links | |||
Charlie175
Orange Level Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6353 |
Governor spring affects RPM, also lighten the weights up. How much I don't know.
Ask WI50 as he has a high RPM WC/D |
Charlie
firephight
I know about the spring but do you swap it with a diffrent spring or adjust the weights some how to get it 20º over stock
Charlie175
you could run 1680 RPM's which is a little more than a stock D17 makes (1650).
DRAllis would know best or Mack. I think you could run a "E" engine spring and gain a lot of RPM's Search the main forum on governor springs, there was a conversation about the subject last winter |
Charlie
Charlie175
go here and see the governor assembly. The weights are not adjustable.
http://www.agcopartsbooks.com/PartsBooksN/Viewer/book.aspx?book=agco/79001544 |
Charlie
Orange Level Access Joined: 12 Sep 2009 Points: 19713 |
A WD45 runs 1700 RPM wide open no-load.....20% over that is 2,040 RPM. A model D17 stock governor spring will get you 2,000 RPM with a PROPERLY ADJUSTED governor. Sounds pretty simple to me. Both tractors use the same governor weights. I don't know how many more times I need to post this info.
mlpankey
Orange Level Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
firephight
Gleaner "E" is around 1800-1850 RPM and does not have an idle plunger. Each tractor engine is capable of a high idle stop screw located on top of the governor front cover. If your engine doesn't have one, the cover can be drilled/tapped for one. This just allows you to limit the top speed so you don't go over an assigned RPM.
mlpankey
Take the weights off throw them as far as you can. Turn a pice of aluminum with a step to hold the spring from a rocker shaft drill the center to slide over gov. shaft cut spring to length with other end against the side of pilot bearing the weights were against. Then its a matter of how far you pull the throttle and the size of carb. That will dictate rpms
Fields
Orange Level Joined: 25 Apr 2011 Location: Reedsburg, Wi Points: 359 |
And then BOOM.
Butch(OH)
Orange Level Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3831 |
I think it was KA-BOOM
Glockhead SWMI
Orange Level Joined: 12 Sep 2009 Location: South West Mich Points: 2657 |
Viola! Pistons removed from the bottom!
THE-MAN
Silver Level Joined: 11 Mar 2013 Location: By the lake Points: 156 |
I think it was more like "bang" cause no one ever saw it run long enough to decide if it had enough power to go "KA BOOM".. Just bad cobbleing.
THE-MAN
On second thought, It mighta just made a fart noise..
Charlie175
Can't we get through 1 thread without this?
Charlie
mlpankey
Edited by mlpankey - 19 Jun 2013 at 5:41pm |
blue924.9
Orange Level Joined: 22 Mar 2013 Location: George Iowa Points: 1082 |
So now you are telling him to cheat you have truly stooped to new lows |
blue924.9
There isn't a word for a guy like you..... Jeez I hope you shrivel up in a ball of waste when you blow up a motor because it doesn't have a safety device called a governor and you hurt someone. This is assuming one of your motors can even make it far enough to hook to the sled Edited by blue924.9 - 19 Jun 2013 at 6:21pm |
mlpankey
yeah there is its Winner. Winners always have a advantage
blue924.9
You are truly a piece of , if you win so much how come there are always pics of your motor in pieces in a bucket or in an oil pan |
blue924.9
mlpankey
thats others posting stuff to make the inexperienced believe that so they can take your money by eliminating me as a consideration to do work for you . I do not build anything that can not be blown up by anyone. I have two builds in shop for others now and working on a price for a complete engine from carb to oil pan for another this week. 423-472-0896 shop or cell 423 242 8596 .If you call shop ask for Mitch or Ed . If you call cell you get me directly. when did you start pulling? You've been asking a lot of newb questions even posted that. How many engines have you done for others?
Edited by mlpankey - 19 Jun 2013 at 6:31pm |
blue924.9
I don't do engines for others cause I can be a big boy and admit that I can't do it I don't go blow other people's stuff up. Also I have zero wins and zero loses, but its still a better record than you have
Kip-Utah
Orange Level Joined: 14 Sep 2009 Location: Southern Utah Points: 855 |
I have never pulled anywhere that did not have a rule that requires a functioning governor. I have seen guys with bush league devices to override the governor, but have never seen this chicke sh#^ approach work better than a properly adjusted and functioning governor. Kip
HANSEN'S OLD ORANGE IRON. Showing, Pulling, & Going!!
THE-MAN
Hes telling the truth folks. He does not build anything. Hes also saying his stuff can be blown up. We find these truths to be self evident... |
firephight
OK ENOUGH IS ENOUGH STOP POSTING ON MY TREAD ABOUT PLANKY I COULD CARE LESS I AM HERE TO LEARN! !!!!!!!!
Ihateillinoisnazis
Orange Level Joined: 15 Jan 2013 Location: By The Lake Points: 273 |
YOU WANNA YELL, I CAN TOO!!! READ DRALLIS'S POST!!!!! IT HAS BEEN EXPLAINED. UNLESS YOU WANT TO GO ON YOUR OWN AND TAKE THE GOOD ADVISE OF THE SPUNKSTER. Had enough with the ALL CAPS yet??? |
firephight
I have got my info! and hate that everyone has to high jack a post bec planky has posted his usless knowlage
blue924.9
Simple solution pank goes, everyone else but him goes,or he puts on his big boy pants and shuts up, realizing he is spilling complete crap or telling others to cheat in this case putting other people besides his own stupid self in danger. And that's putting it nicely. Petition to the moderator anyone?
Edited by blue924.9 - 20 Jun 2013 at 7:14pm |
