flashing the field
junkyardjewels View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkyardjewels Quote  Post ReplyReply Direct Link To This Post Topic: flashing the field
    Posted: 26 Mar 2013 at 5:06pm
Just did the head gasket on my new to me toy but when I went to put the positive ground on the battery I get a small spark and can hear the generator click inside. Told to flash the field because it sat for so long, not too sure what goes where. Battery - goes to f and + goes to A ??  any help or ideas
Bill
Post Options Post Options   Thanks (1) Thanks(1)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2013 at 8:48pm
Sounds like you don't have things connected correctly. F on generator to F on regulator. A on generator to A or GEN on regulator. Battery to BATT on regulator. What you're wanting to do is "Polarize" the gen. Momentarily jump across the BATT and GEN/A terms on the regulator. Don't do anything with the field.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2013 at 9:44pm
If you have a cutout on the genny, it may have a stuck contact (can also happen on a regulator). This would feed power into the genny causing it to heat and drain the battery. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2013 at 10:02pm
i thoughts...he meant he dropped his drawers out ina field!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2013 at 5:39am
That's for ripening the early tomatoes!
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkyardjewels Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2013 at 5:44pm
it was a stuck contact, new set of eyes found the problem
This page was generated in 0.250 seconds.
