Small Block V8 Conversions |
Claus
Joined: 09 Dec 2009 Location: Hebron In Points: 1166 |
Topic: Small Block V8 ConversionsPosted: 16 Jan 2010 at 6:20pm |
Has anybody her successfully installed a V8 in a tractor, any brand motor, any brand tractor. Just wondering what people have come up with.
John (C-IL)
Joined: 11 Sep 2009 Location: Illinois Points: 1654 |
Posted: 16 Jan 2010 at 6:46pm |
All the time and all kinds. I have seen V8s in WC,WD and WD45's. H's and M's and even the lowly 8N had the Funk comversion. It is the simplest in a tractor with a frame. But there was a very nice AC B with a V8 in it. You are only limited by your pocketbook and imagination. I have a 1950 WD with a Chevy V6 in it.
CTuckerNWIL
Posted: 16 Jan 2010 at 6:58pm |
I have never done it but have seen some nice conversions. The Funk flathead V8 looks nice in an 8N. I have seen pictures of a 2 cylinder JD converted to a V8 diesel. The only problem with that one was they used a 350 GM diesel. http://www.youtube.com/watch?v=MlZafyxLQuo
CTuckerNWIL
Posted: 16 Jan 2010 at 7:05pm |
And here is an Orange V8 conversion. Can you say respirator? http://www.youtube.com/watch?v=PAKRumASmVA
Claus
Posted: 16 Jan 2010 at 7:09pm |
One of the nicest ones I have seen (only pics) was a Farmall Supmer M wide front with 345 International engine, although I don't think much of those motors.
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4939 |
Posted: 16 Jan 2010 at 7:20pm |
my favorite, real clean job, from the GOTO 2000
wayneIA
Joined: 17 Oct 2009 Location: Waverly, IA Points: 268 |
Posted: 17 Jan 2010 at 8:33am |
One person I know bought a D17 with a 350 chevy in it, the two that built it used a diesel frame to have enough room for the motor, but finished it looks about like it came off the assembly line.
John (C-IL)
Posted: 17 Jan 2010 at 9:32am |
Here's a WD45 with a V8 in it.
Here's another one with 8 cylinders!
Edited by John (C-IL) - 17 Jan 2010 at 9:40am |
redline
Joined: 11 Sep 2009 Location: Collins, IA Points: 1013 |
Posted: 17 Jan 2010 at 9:39am |
I guess when my father was growing up, our neighbors had an RC they were very disappointed in the performance of. These neighbors were/are very creative, and installed a flathead Ford V8 in it. I think they ran it quite a while that way, and it had a good road gear then as well. We are still neighbors with one of the brothers, and he is a great guy with a lot of talent for metal and wood working. This must have been a fun neighborhood 40 to 50 years ago. Now there is (are?) only a handful of families out here, and even fewer with young families.
7060
Joined: 16 Sep 2009 Location: Missouri Points: 1155 |
Posted: 17 Jan 2010 at 9:40am |
How do they convert the 2 cylinder JDs with the crank running sideways to a V8?
GBACBFan
Joined: 11 Sep 2009 Location: Green Bay WI Points: 2662 |
Posted: 17 Jan 2010 at 11:02am |
I saw and heard the first tractor John posted above at Hutch, and that tractor was whisper quiet, and a high quality build. Note the hydraulic pump on the pulley flange also. That is a very nice tractor.
are genuine." - Mark Twain |
Gerald J.
Posted: 17 Jan 2010 at 12:36pm |
The V-8 JD gets the engine crossways.
The flat head Ford V-8 is a natural for the 8N because the 8N engine was just half of the prewar flat head V-8. May have even shared parts like cam gears, rods, and pistons. Gerald J. |
Claus
Posted: 17 Jan 2010 at 4:43pm |
Really??
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25547 |
Posted: 17 Jan 2010 at 4:48pm |
Is that what is known as a loose track? LOL
LouSWPA
Posted: 17 Jan 2010 at 4:49pm |
is that what's known as a loose track? LOL
Hey, don't look at me, I have no idea how I did this! Sorry for the double post Edited by LouSWPA - 17 Jan 2010 at 4:55pm |
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4582 |
Posted: 17 Jan 2010 at 6:22pm |
There was a "G" at the GOTO in Hickory Corners Mi that had a front mount small block Chevy. Transmission was a mix of G and B parts.
Calvin Schmidt
Posted: 17 Jan 2010 at 6:25pm |
Just remembered that the was a hot rod "G" with a lawn mower and an OLDS V-8 in the back at the GOTO in Portland 2008. It was on a trailer in the swap meet area.
jzyta
Posted: 17 Jan 2010 at 6:29pm |
Talk about over powering something!!! Hi Calvin how's it going. I am now in the process of re-assemblying the WD-65 new gaskets etc.. making sure I am free of any leaks. After unning her this summer discovered I needed to replace a bearing in the tranny nothiung serious. The tin work is all painted ...should be ready for plowing this summer. Jim |
CTuckerNWIL
Posted: 17 Jan 2010 at 7:11pm |
The V8 JD that I saw used a ring gear on the original crankshaft and drove it with a pinion connected to the engine. The clutch and transmission are all left factory. The engine sets in just like any other, front to back. Lou, I think that could be called a loose track or it might be caused by drought. IDK
Jacob (WI,ND)
Joined: 11 Sep 2009 Location: Kenmare, ND Points: 1249 |
Posted: 17 Jan 2010 at 7:27pm |
Here is one I just came across on youtube:
[TUBE]bRofJ7D5Jyo[/TUBE]
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45 |
Gerald J.
Posted: 17 Jan 2010 at 7:29pm |
I could have been thinking of one of th concept new generation Deere. For sure the V-8 would need that speed reduction to the two cylinder crank shaft to be able to do any work with the original transmission and final drive gears in any of the JD two cylinder tractor frames.
Its probably been done with a locked differential and with a couple spur gears with crankshaft fore and aft and also crosswise. Gerald J. |
JoeM(GA)
Posted: 17 Jan 2010 at 7:50pm |
this G was at Portland GOTO 2008
Claus
Posted: 17 Jan 2010 at 7:56pm |
WOW!! That G looks like a cross of something from The Road Warrior and the lawnmower from Moving (Randy Quaid had a push mower with a small block Chevy).
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Geeez! Now that is what I would classify as a wake up call!
Brian Ahart
Posted: 17 Jan 2010 at 8:02pm |
Here is Marion(AR)'s V8 B at the 2000 GOTO in Washington, KS:
Jzyta, keep us posted on your WD-65 reassembly. I enjoyed your progress pics in previous posts on the old forum. |
A-C Weight ID reference and other goodies at brianahart.net
codey lowe
Joined: 01 Jan 2010 Location: Irwin Illinois Points: 8 |
Posted: 17 Jan 2010 at 9:46pm |
This is my grandpa in 2007 at a tractor show in momence illinois, this show has only been around for a few years now and they wanted to try something new so they came up with tractor mud drags. my grandpa has owned this tractor since the early 90's and decided to race this f-20 with a small block chevy 350. i just started putting a 6.5 GM diesel in another f-20.
Denis in MI
Joined: 15 Sep 2009 Location: Norvell, MI Points: 832 |
Posted: 17 Jan 2010 at 10:39pm |
I am getting things ready to put a fuel injected ford 300 in an old F-20 parts tractor I have. Hoping with 38 inch rears and the speed of the truck motor I can ge a decent road speed out of it and maybe a decent puller.
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
