"B" Questions and Ideas? (plus pics) |
R.W
Orange Level Joined: 31 Dec 2010 Location: Swanton, OH Points: 2975 |
Posted: 07 Oct 2012 at 10:01pm |
First off I just want to let you all know that the "B" that I acquired this spring is still running good and is fairly trouble free. I have been fixing little things as time permits, and I use it for everything possible. I never knew it would be so nimble and handy. But I have a couple questions/ideas. First off, where am I suppose to store the hand crank on a electric start tractor like this? Or was there never a designated spot after the battery took it's place? Second, where is a good place to fasten an extra tool box? Not that I need it, but I think it would be a welcome addition. Since this B is a 1955 it has the CA style torque tube. What are you guys thoughts on fasting the tool box on the RH side of the torque with these two bolts?
I am still thinking about the addition of a pioneer coupler to aid with running the hay rake. Time will tell, and pictures will follow. But here are a couple photos that I have took and not yet posted on here. Here it is pulling the few pumpkins that grew this year. Here is at our local fair in the tractor games. I just wanted to take a picture this day. Edited by R.W - 07 Oct 2012 at 10:02pm |
Murph-NC
Orange Level Joined: 11 Sep 2009 Location: Western NC Points: 797 |
Not sure about the crank storage, but here's a good thread on toolboxes... http://allischalmers.com/forum/forum_posts.asp?TID=44201
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
CTuckerNWIL
Dad always tucked the crank in behind the seat shock on the platform(1951 CA). I found out it hangs very nicely in the steering support bracket in front of the toolbox. Since you don't have either, maybe hang it on the wall of the barn like a lot of farmers did.
Classic picture..... Edited by CTuckerNWIL - 08 Oct 2012 at 1:01pm |
morton(pa)
Orange Level Joined: 11 Sep 2009 Location: Lancaster, PA Points: 1234 |
My '52 B has 2 pieces that bolt onto the torque tube where you mentioned about putting a tool box. A previous owner took 2 pieces of what look like 90 degree angle iron, placed them vertically, then drilled a hole with a notch on either end (IE The shape of the hand crank end, much like you'd find on the radiator support) and bolted them to the torque tube. This is where the hand crank sits. Unfortunately I don't have a pic.
George Davenport
Silver Level Joined: 20 Sep 2009 Location: Trenton NC Points: 127 |
That B pulling the pumpkins is just in season and would be a picture for a calendar!
Life is what happens while you are making plans for the future
wfmurray
I mounted a tool box on the seat back supports.. size of box is same as box of my d/14.
BrettPhillips
Orange Level Joined: 11 Sep 2009 Location: Strasburg, VA Points: 808 |
I have found that if you completely empty the factory toolbox, and hold your mouth right, the crank will fit inside with the handle toward the bottom rear. Of course, then the battery always goes dead when you have three screwdrivers, two adjustable wrenches, a pair of pliers, two hitch pins, an oil can and a rag in the way... ;-)
Ted in NE-OH
Orange Level Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
I think when Allis put electric on the B the must have thought you would not need the crank, especially in the later years when they went to battery ignition.
Ted J
Orange Level Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18728 |
I just did this with my crank. I drilled a hole in it in the right place after I stuck it through the hole, just short of the pulley. Put a washer on and then put a cotter key through it. Won't fall out now.
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5644 |
Hee hee... yep, awesome picture!!!! And this answered another question that has been perplexing me for a long time...
My '48 B is electric start, with magneto... non-adjustable front end, but 5-lug rearend with wheels just like yours. The combination of wheels has always perplexed me, because every other reference I'd gotten, indicated that they were wrong wheels... now I know that mine is not alone... BTW... I store the crank for my '48... on my '38 hand-start. Works great!!! |
CTuckerNWIL
Brett, you forgot the 3 gallon mouse nest that holds it all together |
Krazy Karl
Silver Level Joined: 12 Sep 2011 Location: SE MN Points: 203 |
On my C there is a couple hanging brackets on the left outside fender where the crank goes.
R.W
Thanks for the comments and ideas.
Bill Long
Orange Level Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Brett, Charlie, You are both right. Yes, when they came new from the factory the crank along with the standard tools were in the tool box. I tried for years to get it back in and ended up thinking that the put the crank in then mounted the sides on the box.
Yes, the crank will fit there but the box must be empty and you need patience. Nice looking B. Take good care of my favorite. Good Luck! Bill Long |
