Painting in Cold Weather
Knight63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Knight63 Quote  Post ReplyReply Direct Link To This Post Topic: Painting in Cold Weather
    Posted: 03 Oct 2012 at 7:31am
Hello Everybody, my dad thought that there might be some problems with painting in colder weather. Is this true? Would I be better off waiting until warm weather comes back? Also, what is the appropriate color of orange for a 53 WD? Thanks a lot.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 7:45am
If your are painting when it is cold out, but you are in a heated shop you will be fine.
If your outside and its below 55........well good luck
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 8:09am
Persian Orange 1 is the right color.  PPG 60080
Allis-chalmers wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 8:39am
I painted my c in the middle of the winter but I had a heated shop make sure you do too or the paint won't adhere properly ... Persian orange #1
1946 "C"
1956 "WD45"
1965 "D17" Series IV
1979 185 factory ROPS
deutz allis 385 planter
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 8:58am
well darn guess it looks like my wc isn't getting painted this winter
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 9:22am
We used to paint nurse tanks at the fertilizer plant down to about 50 degrees, however as long as they ended up white nobody cared too much about the finish. LOL
One day we rolled a pair of tanks outside right after painting them, that afternoon the temp dropped and that night it hit freezing. During the next season the paint flaked off those tanks so bad we had to repaint them again.
AGCO My Allis Gleaner Company
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 11:19am
Also check what temperature range the thinner is formulated for. You wouldn't want to use a slow dry thinner for summer in cool weather.  And possibly you might want to use thinner coats with longer drying times between coats.  Good luck!
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 4:27pm
Dipstick hit a important point, if you are using "real paint" instead of "hardware store" paint there are diferent cure times on the reducers available, however there is a limit as to the coolest alowable temp -- your pain supplier can help you out with this.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 5:19pm
I'm not sure I'd go that route?  Ouch
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 5:40pm
Stan and the other guys have good points, and should be considered! However, with careful planning it can still be done by paying close attention to the weather and managing your painting to areas you can control. Like for instance, if the weather shows a daytime temp in the 70's and a nighttime drop of 20 degrees, paint early in the day, and paint small enough areas that you can get drying accomplished. Small parts can be taken into a garage or small shed to protect them. A chassis can be tarped to retain heat.  It depends on your schedule and time frame.  Again Good Luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Knight63 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 8:03pm
Thanks alot for the help everybody! I think I'll just wait until next year to be safe. This is the first thing I will be painting so I don't know what I'm doing.
CAdon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAdon Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 10:11pm
it sure helped me to paint something else first.  in my case a little garden tractor & trailer.
maybe an implement?  i definitely feel better about painting the CA now.  there is a learning curve...
52 CA, 41 B and a little B1    oh, yeah... and an 8N ford snuck in there, too.
This page was generated in 0.067 seconds.
