D-15 power steering fluid
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Topic: D-15 power steering fluid
    Posted: 12 Sep 2012 at 10:03am
Can't find where I left my OM, and want to top off the fluid. What oil is called for in the operator's manual. Thanks.
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 12:36pm
Hmm No reply yet...  We put regular hydraulic fluid in our series I D17
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 3:17pm
I use universal trans hyd in mine
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 7:25pm
In my 15II I use red ATF!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 9:06pm
ATF in mine too
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 9:26pm
ATF or Dexron is what the owners manual recomends. Modern day universal hydraulic fluid is better and unfortunately they don't go out and re-write the owners manuals.
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2012 at 8:47am
type F ATF
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2012 at 9:45am
I use the Ford ATF as it meets the original spec called for. On each tractor I pick up, I get the PS good and warm and drain the bolster as you may be surprised at what comes out. One D15II looked like it had never been changed, was low enough to see the crescent gear pretty good, had a few line fittings leeking and did not steer near as easy as the other D-Series. Got her warm, dropped the fluid and honestly do not know how the pump handled the sludge like it did. With the drain plug out, poured 1/2 a qt. of ATF in her and still got crap out. Re-filled with new and dropped it again after a couple of hours of running so I could get what was originally in the pump/lines, plus what crud had settled on top of the gear. Much cleaner and that D15II steers easiest of any of the five D-Series I have with PS. Clean the breather cap as the dimples on the cap can completely plug of (that has the mesh inside), soak that in diesel or solvent to clean it and I do a final clean with gas and let dry overnight. Mine was also full of crud and the hex cap did not have the gasket.
Sandy Lake has the nylon gaskets and if memory serves, it is the same size as others used on the D15/D17.
If I can't see the gear through the fluid 1/4 - 1/2" above the gear, I change it and re-clean the breather cap. Those PS pumps will go a long time if you can keep em clean.
