20-35 Poor idea
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Topic: 20-35 Poor idea
    Posted: 11 Aug 2012 at 10:08pm
Is this the way they all are? You have to pull the pan to get the flywheel off?
https://lh5.googleusercontent.com/-rx3b2rgTyHI/UCW0biOGOSI/AAAAAAAAFao/aXHRvIukTcg/s647/DSCN5898.JPG
Or are there 2 pieces and the clutch drive can be take off separate?
Edited by CTuckerNWIL - 11 Aug 2012 at 10:09pm
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 10:52pm
That is the way she is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 10:54pm
Remember Charlie, they were still trying to figure out how they were going to build a tractor.
Leesok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leesok Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 1:11am
Pan, upper pan, and crank best I remember.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 6:41am
Well the tractor was split cause the clutch wouldn't hardly pull it around and the bosses son thought he would have me take a clean-up cut on the flywheel. I said, set the whole thing up on the boring mill and I can do it. He acted like I was crazyErmm It made sense to me, no further tear down and I can swig a boring bar in there just enough to smooth out the clutch mating surface.
 He also found a whole bunch of slop and wear in the clutch linkages, so the back half will be tore down and holes bushed or repair somehow along with new linings.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 6:47am
Both pans ,and just rear main bearing cap.Then you can remove one stud at a time as you turn the crank to 6 oclock for that stud .
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 6:48am
So when this is separated from the fly wheel,
https://lh3.googleusercontent.com/-XZ93xaLovGo/UCW0UAG2gaI/AAAAAAAAFag/5sbu4ikRa_I/s647/DSCN5897.JPG
it seems to float fore and aft. Does the front bearing in the fly wheel help keep it from floating around when assembled or is there something wrong with the rear bearing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 7:24am
That bearing is your polit bearing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 8:07am
Maybe not a POOR IDEA not just what most people are not use too.LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 9:18am
I know what the pilot bearing is. My question is about the clutch itself. In the picture, with the tractor split, you can grab a hold of the pilot bearing or the whole clutch and move it front to back, up and down and side to side. The up down and side to side movement would be controlled by the pilot bearing but, what controls front to back endplay?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 9:52am
There realy is not front to back  pressure as there are straight cut gears in trans  and when clutch is  engaged it pushes out as you know ( not like when you have a finger clutch pushing crank froward ). Give me a call today 717-451-6590.I am too busy on week days .
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 1:03pm
The bosses son is taking it apart and I haven't seen back inside of the clutch yet. If I have any good question after seeing it apart, I'll post here or call next weekend. Thanks!
